Absolutely awesome
Nice work. Very detailed.
Is this going back to stock? Build plan? Please don’t say theme bus.
Thanks all! Current plans are to get it back on the road with a few modifications to make it more of a practical driver. I have a nice motor that’s been on a stand too long and slated for cars I don’t even own anymore. I’m building an adjustable, ball-joint beam from a 68 and also plan on an IRS conversion from a similar year Bus. It’s going to be stock height or pretty close to it with some off-road tires.
So the theme is; fast, comfortable, handle well on and off road with a sunroof, comfy bed and a lot of windows.
While it’s running and I’m able to enjoy it, I plan on picking away at little parts to make it better and better. Eventually I’d like it very stock and maybe an Okrasa or early 356 motor, though that’s a long way off.
I initially wanted to try to save the paint that was underneath the re-spray, but after some stripping and scrubbing, I don’t see that in the cards. The Bus looks like it spent some time on it’s roof or side at one point and when it was repaired they took off quite a bit of paint during preparation. I dig those builds where they touch up around a stamp sized piece of OG paint but that’s not for me. I think you have to be British or German to be qualified for that type of build.
Here’s what I found under the re-spray:
If the whole Bus looked like this, I would leave it, but there are other sections that are just bare with red primer and there is virtually no Chestnut in the mix. I’ll just prime whatever I end up fixing.
The apron was chopped up like the rear bumper.
I still need to spitznagel a couple of dings that sit behind the apron, but the heavy lifting is done. I’m glad I was able to keep the spot weld marks below the crease and plan on leaving those when it’s painted. I don’t think that area is totally smooth on an original Bus.
I’m starting on my Bay beam for the Samba and have a question. What better place to ask a question about beams than KCW, right? I only plan on lowering it about a notch in order to get it near stock, split bus height. Apparently a Bay beam will make a split sit a little higher from what I’ve read.
Will I need to remove or relocate the bump stop arms from the ends of the beam if I go down just an inch? I chopped these off of the last couple of beams I installed adjusters in but they went lower and higher than I plan for this one. Thanks in advance for your expertise.
I doubt they would be a problem.. but.. may not have enough down travel for a split???? What makes you want a BJ beam in a split bus?
Nice work! How many hours did you spend on that bumper and apron?
Keep in mind that that lowered buses usually have smaller tires…meaning that the bump stop may leave an inch or two before the tire starts rubbing…..I’d cut down the rubber disc or leave it out.
