Put in a little more work on the door for the 60.
That bottom is a complicated, little piece.
The inner skin was pitted more than I like, so it’s getting some new metal.
Rust was removed with toilet paper soaked in muriatic acid. Pretty effective.
Burned in and metal finished. Next is to weld in the lower door frame, then trim and turn the edges of the lower skin.I’m straightening out the inner, u-channels which support the door skin. I don’t see where these were spotted to the door skin, only welded at the top and bottom of the frame. Were these originally spot welded to the skin? Mines been so displaced and surface rusted for so long that I can’t tell.
I had this beauty come by the shop for a new engine compartment tray and some other things. I made the door tops for this car years ago and had never even seen it until last week.
Cool car/cool owner.
Speedster #40 from 1954:
not to the skin👍🏻
not to the skin👍🏻
Right on, thanks! I think I’m going to get the door in epoxy, then seam seal the braces to the inside of the door followed by spot welding the supports to the frame.
While I’m working on this thing, I think of all the things this Bus could be; Highroof, Sunroof Double Door, Camper, Panel…. I don’t know? I do know that it needs doors, so I’m going to focus on that and removables for now. I also know it will be Dove Blue. Never had a DB Bus before.
That door is looking amazing Mike!!!!
Thanks, Man! A little more to do, then on to the next door. Hopefully I’ll be back to driving a Split next year and join you guys on some adventures.
With the passengers door out of the way, I’m moving on to some cargo door work. My panel doors were pretty worked; camper window hack, rusty and damaged bottoms, you know….
I’m going to de-skin some window doors, make some skins from the beltline, down and weld it all back together.
Not a whole lot done, but I have to share how impressed I am with this muriatic acid rust removal. Before and after pics are less than 24 hrs. apart. This wont matter much if you have a nice blasting facility, like John, but for those working at home, this could be a real help.
I left some acid-soaked rags on the front bumper of my 914 last night in an effort to remove the chrome. I’ll let you know what I find out.
