This gonna be your vw shows driver this year?
Not sure.. It’ll be hard to leave the notch parked with a fresh engine!
BTW… I’m on the lookout for some old school 90mm barrels. I have a good used set of 90mm pistons, just need barrels. My first VW engine was a 1756. I’d like to rebuild it for this car.
Started doing a bunch of rust repair on this thing. Before long the car was stripped apart and 2 gallons of zenith blue single stage “super wet look” was ordered. All the small shit is painted. Still working on the body, doors, fenders. No pics.
Played with some gas tank fab. Took an 80mm oval window filler neck and added a few inches to it, then welded it to an aftermarket 62-67 tank.
I’m collecting up a set of 944 spares. I have 3 so far. If anyone knows of a deal on one or two more, let me know.
Love your plans. Watching this one for progress.
nice gas cap…. 😎
All work and no play makes JJ a dull boy🤣
Keeping a lid on it😎
Attitude is everything 🤔Cool gas tank filler. Thats a subtle mod.
Got the engine finished for the RHD. Haven’t ran it yet though. Probably break it in next week. Took some inspiration from Franz’ and the 356 styling on his 36 horse engines.
That looks great Justin! 👏🏼
Type-1 1853cc
AS21 VW case
Cast counterweighted CB crank
• Offset ground from 69mm VW to 72mm Chevy
Chromoly I beam rods 5.4″
13.5 lb lightened flywheel
Scat chromoly gland nut
Kennedy stage 1 pressure plate
Kush Loc disc
AA 90.5 pistons
Teflon wrist pin buttons
Engle VZ-15 cam
CB pro straight cut cam gears
Engle lifters
Berg 80k psi chromoly push rods
Welded fan
Type-4 oil cooler
Shadek 30mm oil pump
NGK D8EA spark plugs
CB Panchito heads
• CR 8.5:1
• 40×35.5
• Manley stainless valves / Engle single springs
Stock 1:1 rockers with Scat swivel feet
HD solid rocker shaft
1.5 quart Puma sump
A-1 1.5” ceramic coated header, V-band
Dansk 1.5” heater boxes
40mm Weber carbs
• 34mm venturis
• Jaycee push/pull linkage
Pics of the car sometime would be nice…..😁
When there’s picture worthy pictures.. I will post them… 😀
Very cool engine, Justin!
That motor looks awesome!!!!!!! NICE detail… Never thought about detailing the fan belt!!!!!!! damn!!! 😎
Attitude is everything 🤔 -
