I gotta check VIN numbers, bet our Buses were built at the same time!!!!👍👍👍👍👍
you have a trans here, and big nut reduces and bearing kits in Durango?👍🏻
Never make someone a priority, that makes You and Option. 🤔🤔🤔🥲
What you need is for me to bring over that center section and do all this work at RCW??? OR. You bring the boxes hete, we assy it all here you take home and install?? OR. Bubba might help😎😎😎
Do you know bubba ????🤫🤫🤫🤫🤫
I’ve got a big nut core here but I still wanna get that small nut together. I think that’s a bigger project than RCW can handle, either you or Painters or both is gonna be needed for the tranny assembly’s 👍👍👍👍
The center section does not care what boxes you put on it… Soooo.. You can use this rebuilt center that’s here, bring the big nut boxes up here and we will blast, paint, and assemble on the trans that’s here, and it will be ready to put in the 64! Clear? 😎 Bring the brakes too… 😎
We can then send off the center at your house now to painters. 😎 I guess bring it up here with you.. And put your small nut setup on that rebuilt trans…
Sounds like a Plan!!!!👍👍👍😃 it’s funny and annoying that EVERY Bus I own has had the transmission pulled out for a Baja Bug back in the 70’s or 80’s!!!!!!😂😂😂😂😂😂🤔🤔🤔
Rusty when are u headed to kcw. I have big nuts tranny I need to build out and install RGB. Maybe we work together we can help each other 🤪
😂😂😂 John Jones Nighmare!!!! BOTH OF US IDIOTS AT KCW WITH BROKEN TRANNYS?!?!?!?!? I’m Totally happy to give Jones a headache with my dumb shit but this might be Too Much!!!🤔😂🤔😂🤔😂
😎 😎 😎 You guys know I am a small nut guy right???
Just let me know when!!
