Home › Forums › KCW Current Projects › Cory’s 1964 class 11
Here to prep for Crandon. Step 1 is to take everything unnecessary off. Then fix the fenders and stuff… I hope we can do a quickie paint job. It has some kind of VW Paradise engine too. We need to test jumps and dial-in suspension/tires/pressures next week….probably towards the end fri/sat? Anybody know a good jump?
We beat the stink off of it this evening. Started making a list too…
Love them Yokohamas.
Already getting faster. 😉 Thats like 200lbs of junk.
Cory, are you cool with welding in A-pilar to beam tubes, and B pilar to torsion housing tubes? The car needs them complete the structure + strength.
Worked on your rig some yesterday.
Looked over the cage additions were going to make and decided the knee basher dash bar had to go.
New one bent and fit.
A-pillar to upper beam tube bars up next.
More progress. Dash bar welded.
Pass a-pillar to upper beam bar and the vertical brace bar fit and partially welded.
Great work guys. Race car building is great fun to watch since I don’t have to pay for it.
Finished up all the front cage mods this evening. Fitting the drives side bars.
All fit and happy.
Everything welded.
The boys did as I figured they would on Cory’s rig…. Tear it ALL apart and start fresh with things and a clean view of what to do.. 😎 There is no doubt in my mind, that you would bend, or and break your beam without those bars… I have done, a few times… 😎
The car needed a new look at things.. Cory should be here today and see the direction Franz and Pat want to take him.,
Only two weeks though… So a priority list will be of huge importance!!
I heard a repaint too?? L31 army? hummmm 2 weeks… 2 weeks..
Retired 😎 😎
Good move Cory, getting your rig in the right hands. looks awesome
That didn’t take long! You guys move quick!
The camshaft measures out pretty good. .455-.464” would be in the engle vz14 range. But we don’t know what the cam is…Lauffers probably have a special grind or something anyway.
I’m going to retorque the heads/adjust valves and call it good.
The head studs were way loose. Re-torqued to 30ft/lbs. I noticed some missing valve stem lash caps on the 3/4 side…So, installed some new ones. Also had to swap out the rocker studs as they were about to strip-out.
Valves set to .001” for steel pushrods.
I like to weld some tabs on the valve covers to prevent them from slipping around and washers to wire tie the bails in place. You definitely don’t want to lose a valve cover in a race. Easy to do if the apron gets banged around much.
