Home Forums Bullshit Rustabaja
Viewing 15 posts - 46 through 60 (of 346 total)
  • volksaddict
    Do work Rusty!
    What do you mean clunky? Motor? Chassis? steering?
    Re- index the torsions to jack up the ass end? I have the tool if you need it.
    I thought you and JJ had this rig dialed?
    Baja bugs have a hard life. They get thrashed and minimally maintained.
    Case in point: You are more concerned with the roof rack, than the things that make it drive nice. ๐Ÿ™‚
    Hahaha, the roof rack ! Im the same. First thing I did when the DD arrived home was put the rack on it. My friends were busting my balls…
    I think it badass Rusty
    Iโ€™m gonna keep at it it til itโ€™s nice!!! We cranked up the rear at KCW but it still sags, gotta go up more!! Also need bigger rear tires, torsion adjust, Clutch tube fix, some electric, tinkering……
    82D8AC76-0BBB-44AD-8718-9E074034837EYou need this rack Rusty! More solid for your motorized bicycles. I donโ€™t know how he wouldโ€™ve got his motorcycle up there… steep ramp I guess
    7D4F4A8F-A678-4143-8043-C23872087AC0Yeah!!! That could be the Gen2 version!!! ย  Rack is a little rear heavy but itโ€™s bolted to the body now ๐Ÿ™‚ Better suspension and faster throttle/clutch response is needed. Iโ€™ve got soft brakes…….. kinda seems like Iโ€™m gonna build and rebuild this rig a few times til itโ€™s a nice Baja ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚ Makes me re-think โ€œoverpricedโ€ $6000 Bajas that ย have everything sorted!!!!! ๐Ÿ˜‰ Iโ€™ll get there!!!!!! ๐Ÿ™‚
    You probably need to buy brand new rear torsion bars. Yours seemed a little soft. It will take a mile of pre-load to get the suspension height where you want it.
    52ADAE6E-D507-4930-9167-19CC9D8AB74BLike these??? Got em in a tranny deal a couple years back, will they work? Big ass torsion bars, crazy preload, bigger rear tires, Bilstein gas shocks= nice rear end?????????
    yep
    Yeah! Thatโ€™s math I can understand!!! ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
    Those are huge torsion bars. Probably won’t need much if any pre-load.
    They were a โ€œDude, do you want these too?โ€ Sort of thing! ๐Ÿ™‚
    Baja Mark
    Rack looks great Rusty ๐Ÿ‘๐Ÿผ
    57AD1E15-5A1A-4274-B612-F35E195478B1Thanks!!! ย Got a Baja Mark compliment!!!!!!!! ๐Ÿ˜‰ ๐Ÿ˜‰ ๐Ÿ™‚ Cut my tunnel, bracket was broken just like they always are!!!! pullin out the welder!!! ๐Ÿ™‚
    Off the list!!! Not gonna post a pic of the slug weld I put on that bracket but seems like the clutch response is better!!! ๐Ÿ˜‰ ๐Ÿ˜‰ ๐Ÿ™‚ ย Tires!! The Baja has a set of nice Blizzax tires all the same size, part of the stance problem 215 70 R15, wanna keep that size for the fronts and get some 235 75 R15โ€™s for the rears????? Any input????
    Also need rear shock advice!!! No more coil overs!!!! ๐Ÿ™‚
    Where are ya Mark??!?!? Quit buying early Rabbits and help a Brother out!!! ๐Ÿ˜‰
