Home Forums KCW Current Projects Parkway projects
Viewing 15 posts - 2611 through 2625 (of 2635 total)
  • John Jones
    I gave in a decided I would work on Raileys super beetle.,
    hood has seen better days., all kinds of cracks..  no, I don’t have another super hood or I would swap it out!
    E9AC4F90-A480-4341-AD3C-E975626D023D40EDDB89-EE19-4D71-B929-D4A44284554B3BAEF4F2-A57A-42D5-B4E3-4650C6BCFD534A97DC7F-49F3-40B8-8C62-54E53864859648CAC8BB-A09C-4943-A36B-95402AE02403
    Did you look in that pile of stuff I dropped off ? I think there was at least one SB hood in there…maybe orange ?
    Leerjetz
    Sigh…🤦‍♂️
    IMG_2415
    I hope that is more than just last night👎🏻👎🏻👎🏻👎🏻  Bummer !
    But I’ll help again.  Let’s put the main seal flush with the back of the case so it’s up higher on the flywheel area..  no big deal, we’ll be faster this time!
    Audrey Jones
    C08CA32F-E06B-4A57-9598-762C82D89064
    Never make somebody a priority who makes you an option.
    Yup..  between other stuff I have been fixing this hood.  Today I’ll get the fender off😎😎👎🏻
    I did look for another hood.,  and was sure I would find one..  but no..  I had to fix this POS!   It was Rusty and had been pried open many times. Got it, about to undo this..  the back side I had to take out that brace and fix it also.  I ended up dusting the back side off in the blaster..
    0E826B5C-FA67-440C-BEF4-D48452C587AE25F99893-22D4-40FA-A1DB-CA4B886B935F70AD7046-E855-4CE9-8287-AE460C898C12
    Sigh…🤦‍♂️ IMG_2415
    Did anything improve??   That clear line is then”janky” line Franz told you about.  Order a new reservoir and the line!!
    I’ll be more than happy to help try again on the main seal issue., 👍🏻
    For the record, I wish I would have said no to the super beetle girl 👧. But her cuteness got her in the door🤫🤫🤫🤫🤫
    the fucked up hood is back to hood..  got the fender off, now to figure out how to fix this apron.,  it’s not as simple as early stuff🧐🧐🧐🧐🧐🧐🧐🧐🧐🧐
    Gretchen Jones
    Ruby made parkway status! Per John, “easy peasy” fix… ofcourse he has 50,000+ hours of VW repair experience 😁😁😁😁😁😁
    IMG_9930IMG_9931
    What work is Ruby having done? That car has been so good to you all!
    bottom adjuster came loose and she was rubbing hard..   had to raise it up some and grind the ball joint down some more, with the fuch’s and all that back spacing..   😎
    Ended up having to cut this shit out Hammer it out and about to start welding 👍🏻👍🏻👍🏻👍🏻   Power s supposed to go out today…. I better hurry up👍🏻
    D52232CF-EDF2-4AD2-AAA4-68D8C1D98E683085CD6C-355C-476C-9F4B-607CCC5324AC
    When you are sick of Super Beetles I have a rebuilt Bus transmission, painted axle tubes, and a new bearing kit sitting under the bench next to the hardware bins……🤔🤔🤔🤔😃😃😃👍👍👍🙏🙏🙏🙏?????????
    Paul
    That is some smoooth jiiiive!
