Drive-ability today. I was looking at the spring plates. We talked about notching them. I can’t see any marks from them bottoming out on the stops. It seemed to ride decent when I drove it. I’m going hold-off on the notches until I drive it again.
holeeeeeeeeeeeeyyyyyyy shit!!! sounds friggin awesome man!!!!! so awesome! cant believe how smooth it sounds. THANK YOU! THANK YOU! THANK YOU!
๐ ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐ย ๐
Drive-ability today. I was looking at the spring plates. We talked about notching them. I canโt see any marks from them bottoming out on the stops. It seemed to ride decent when I drove it. Iโm going hold-off on the notches until I drive it again.
I was kind of thinking I’d like it a little lower in the back…is that possible? I love the way your red car sits…You’re probably going to say thats too low? lol
Yeah, that is too low for a good driver. My red car drives like garbage…and wearing itself out with every mile.
We’ll take about it more later.
Yeah, that is too low for a good driver. My red car drives like garbageโฆand wearing itself out with every mile.
ok enough said!ย ๐
man I’m so happy you got the motor running sweet. what a great sound after so long of hearing it struggle.
โLife is a waterfall,
Weโre one in the river and one again after the fallโOh shit front end time ๐ Even Dario is hooking me up with pics! Thanks dude!
Damn! Love the KCW Spa treatment!!!!!!!!!!
right??? I guess Iโm moving to Grand Junction so I can be closer.ย ๐
I did my normal rounds on the engine, then went over and tidyโd up a few things.
- nut-zert on the coil
- re-routed a few wires and took off any plastic collars on connections
- swapped faulty electronic ignition for points
- increased idle jet to 55
- measure/marked true TDC
- adjusted advance base line and limit to 11-29 degrees
- hooked-up and adjusted choke
- removed the pre-heat flap from the air cleaner
<iframe id=”player_1″ src=”https://www.youtube.com/embed/qu3351-j0oc?feature=oembed&enablejsapi=1&wmode=opaque” name=”fitvid0″ width=”300″ height=”150″ frameborder=”0″ allowfullscreen=”allowfullscreen” data-mce-fragment=”1″></iframe>Welded the spring brace back to the skin and touched up with some anthracite paint.
Wow this thing has never run this clean, Justin is so stoked! Maybe now I can get a ride.
Wow this thing has never run this clean, Justin is so stoked! Now I need my own VW.
fixed it for you. ๐
