Home Forums KCW Completed Projects Juan’s 59 Lowlight
Viewing 15 posts - 541 through 555 (of 840 total)
  • Juan 59 DDWT
    Nice Gem 😳😳😳,.. Thanks Franz,.. I know you like big engines, but this is the original engine Matching Numbers, I like the Stock engines 👏👏👏👏👍
    Body worked and primer session on gas tank, closing panels and bumper bracket covers today. BB20B0D1-3B4D-4339-AE02-72FCF247A401A580E600-92CF-4DAF-9A10-79F3C448984B
    I like them all. 36hp are a beautiful engine.
    I spent the rest of the day getting the chassis ready for body union.
    CC42C485-0C8D-4CEE-B537-01C1D741155B
    Juan 59 DDWT
    very productive Day, Great Day KCW 👍👏👏👏,.. I think this dream is going to come true very soon 😎
    Franz, have you had an opportunity to install the shift lock?
    Vwsarent4hippies
    So fresh!
    Running the engine this morning, I found a couple problems. The paper gasket under the generator was leaking or off center. I had to lift the fan shroud and glue it in place.
    Then I noticed a fuel leak from one of the banjo solder joints. I’m going to try silver soldering it. We may have to make a new line if it doesn’t take.
    CA133142-6ACF-4B2F-B548-5ED48E7278BD
    Juan 59 DDWT
    Thanks Franz, I hope you can fix it 👍👍👍
    That glass bowl fuel filter is the ‘coolest’ piece!
    Yeah it is.
    Fixed, but I damaged the copper plating with heat. The end is just polished steel now.
    BDC993F5-93BF-4312-864E-808A8796A707
    Brakes fully assembled, adjusted and bleed. Heater control and new cable installed. Pedals finished and adjusted, new Bowden tubes, new throw out bearing and super clips.
    CCC9A88F-4946-4D88-A4C6-710C2FBA76D36E2FC9D2-E683-42A9-BB5B-F50FB8D3CF4539D3FBFB-26EE-48AE-907F-FBBE198BCF30E5EF0EF9-2EB0-4D89-ABCA-CC0C05AE185E
    Juan 59 DDWT
    Thanks Franz, really Good Job 👍
    Scott Sain
    Franz,
    We usually leave the break in oil in for 500 miles. You drain it immediately?
    July 14-15, 2023
    November 17-18, 2023
    www.germanaire.com
    As soon as I turn the engine off. 10-15 minutes of run time.
    The idea is to flush out trash before it settles to the bottom of the case. Metal from lifter/cam and piston ring wear.
    I can tell you the oil drain pan looks shiny like a pearl paint job in the sun. Super fine pieces in suspension.
    As soon as I turn the engine off. 10-15 minutes of run time. The idea is to flush out trash before it settles to the bottom of the case. Metal from lifter/cam and piston ring wear. I can tell you the oil drain pan looks shiny like a pearl paint job in the sun. Super fine pieces in suspension.
    Did the same in the little VW shop where I worked in Georgia. Then refilled with oil after it cooled, reset the valves, and took it on a preset 50 mile drive if it was going in a car at the shop. Drained and checked again immediately, refilled again and another 50 mile test loop before turning over to the customer. On build only engines we still ran and replaced the oil twice on the test stand before handing them over.
    Everything on the pan is done. Ready for the body to be bolted on. Pan seal installed with tacks.
    The sperwolf locking shifter is test fit and ready for paint.
    566DED5F-CA70-4FB2-A71D-B57A2BA6B9BBCCC9B5A2-6CD7-4B9D-B0B8-78B4C11E9980C64B55B1-3F1C-4CB2-A223-FBDBA905F56587E264C3-68D3-477C-9BC0-5630A616B76BD66C3209-4149-4A35-AAE7-12D6804BA0B4
