Home Forums KCW Current Projects Juan’s 59 Lowlight
Viewing 25 posts - 26 through 50 (of 768 total)
  • Juan 59 DDWT
    Totally agree, you make it to look very easy 👏👏👏 thanks for the update 👍
    JJ is a magician. He was still kick as on this rig when I left the shop at 1030 tonight.
    I worked the inner structure along the pass side a couple weeks ago while cutting out the junk stuff and waiting on metal to arrive. I should up date more often. Sorry Juan.
    Few pics. Pass Lower a-pillar carnage.EB745E0B-1DB5-4B83-8EA6-8F6F275C34F4
    Bunch of fiber glass was jamed up into the apillar/rocker area.10BF9A05-C9C0-4CA7-B17E-3A241E4DEC02
    Fabbed up inner patch.83924D89-312B-4515-A394-D81A25D8165F
    Next layer fabbed. Forgot a pic of the wire tube.
    0CB91C60-5A33-44EB-98F3-7DF18EEB5E97
    Small patch in engine bay. 5F44AF59-95C5-4CA3-8F61-0A5AF71A17365C64160D-76A1-497E-90D2-8BB5F18898F2
    Pulled a bunch of ghetto repairs out of the drivers door. Door has some prev damage. Thats metal rod, shop rags, and fiber glass.1334E78E-2189-4551-91E8-A1C53F974C091B9C881F-3523-437B-A8D2-944BF6913F1E
    Pass headlong bucket was fiber glassed in also. ADF777D6-B839-4403-9487-62E20E054BC6953DDD35-C35F-481C-B261-8E8591F615AD1BEDE43D-B6D0-4B7E-8308-B09D44694FDA
    More to come tomorrow.
    Juan 59 DDWT
    Thank Pat for all pics, Good Work👍👊
    Good night last night…. I just kept doing the next step, and before I knew it…. I had a rocker on also….  😎   I;m gonna keep widdling away at it today… 😎
    More good stuff Juan…. I got the rocker all ground..  and the rear 1/4 lower panel fit and welded and ground and front panel in place… You can see the front side where I gotta add for the low light…  Looking good..
    DSCF7202DSCF7203DSCF7204DSCF7205DSCF7207
    They really buggered up those lower trim holes… I think I am gonna have to weld em and redrill….. 8-(
    DSCF7205DSCF7207
    More good stuff Juan…. I got the rocker all ground.. and the rear 1/4 lower panel fit and welded and ground and front panel in place… You can see the front side where I gotta add for the low light… Looking good.. DSCF7202DSCF7203DSCF7204DSCF7205DSCF7207
    Just to get this one the current page. 😎
    Juan 59 DDWT
    Thanks John for pics and info, Good Work 👍
    About the Lower trim holes, 8:(
    Going to put some time in today on this…   Juan… Your making me want to dig out a low light to build for myself!!!!
    Looks like maybe the 56 and 57 out back were trout blue… maybe I can find a spot nice enough to buff?
    Love that there are multiple Lowlights out back at KCW!! 😉 🙂
    Yeah… I went out there to hack off that fender piece from one out back… and it was already hacked over itself….. 😎  so I ended up just bending some green metal and slapping it into place… 😎  Right side looking good.. Inner fender area all cleaned up out rockers etc…  I’ll probably work on this some again tomorrow… 😎
    DSCF7209DSCF7208DSCF7210DSCF7211DSCF7212
    Nice work, making it look easy as usual.
    I’m a bit jealous, Juan.
    Juan 59 DDWT
    Thanks Pete,.. 👍😁
    Perfect John, I’m happy with the Good Job👏👏👏
    Have a Great Weekend!
    I’m gonna see what I can do with this headlight bucket here…   It’s the ugliest part at the moment… 😎  😎
    DSCF7220DSCF7221
    Juan 59 DDWT
    Hi John, I bet you’ll kill that headlight job.😎😎
    That thing looked so nice coming in. Now I see it’s a real lowlight. I think they made those things out of pre-rust. wtf
    Headlight repair is well underway!!!  I quickly figured out that Low light’s have a slightly larger bucket.. larger diameter.  The new bucket will slip right into the original..  and the repair pieces aren’t the right shape around the hole… so… I had to FIX EVERYTHING 😎   I’m about there…  I had to re-ring the bucket… before I can put it in…. But now, everything will be OG!!!  😎  Pics later!!!!!  I should finish it up today..
    OH… Juan… You notice you are missing the bulb holders for your bullets?????  weird????
    Good work as always JJ! Nice freaking car and like watching it come back to life.
    Juan 59 DDWT
    John, I sent an email about the bulb holder,.. enjoy the day!
    well I learned over the weekend that low lights have larger headlight buckets than later ghia’s… and today I learned that 58.5 and 59 ghia’s have the same front turn signals as up to 64.5 ghia… 😎  I guess we are fine… thanks for looking that up for me… ALL the low lights I have built were 58 and earlier I guess…
    anyway.. I didn’t take any during pics of this repair.  it was a pain in the ass.. I had to weld all those cracks up first in the hole on the fender.. then bend up a lip to replace the one on the headlight bucket. grind all that shit, make it fit, nicely, which meant lots more hammer work..  but finally, it is in and repaired, with some blasting and tool mark remover… it will look perfect…. 😎
    Repaired Original Metal… 😎
    DSCF7258DSCF7259DSCF7260DSCF7261
    And I thought that the build was gonna have to get scrapped!!! 😉 😉 🙂 Nice Work!!!!!!!!
    Juan 59 DDWT
    Good Job John, I know it was a difficult area to fix 👍👏👏👏
    it was the usual… fix the rips, add metal where it was missing, grind, dress, repeat… both pieces, fix em both, then marry em together!!!   Thanks..
    I had to work on a parkway buff job this morning.. but back on it this after noon.. 😎  working on this rear lower fender repair area….  I’ll have that done soon and move onto the next bad area.. 😎  eventually we run out of bad area’s….
    DSCF7265
    omr_007
    Man, these are some desirable shit. Thanks for dropping your ‘no more lowlight/type 3 ghia’ rules Jones. Stoked to see another Juan project too.
    I got that side done and starting tearing into the drivers side yesterday eve…  I’ll continue on today!!!!!  😎
    I think these Low Lights are just barely coming around the corner of full mature market Value!!!!!!!!!!  😎
