Home Forums Bullshit Bus door/Year differences
Viewing 7 posts - 1 through 7 (of 7 total)
  • tlambert
    So there was some questions and posts on bus door year differences in Toms thread. Instead of clogging up his thread  with random door pics I thought I would start this thread to get some info on a door situation I have on a bus.
    The bus I’m working on is a 1960 23 window deluxe. This bus overall is in good shape and looks to have all of its OG panels, EXCEPT for the right front door. It had been hit on the right front nose and hinge area and the door had been replaced.
    The right door from what I can tell looks to be a VW replacement door, but there are differences from the left door that are completely different.
    Post any details and info you guys know of as far as the door itself and the latch assembly too.
    I’m going to post pics of the left door details first and then the right door. I had nothing to do with booger welds or crappy body and paint work you may see in these pics  hahaha
    Left OG door.
    20F093F3-2C6B-4E45-AA22-4542CC36C7C3
    C06EEC4C-A6CD-4F63-847E-030BFF387C23
    63E8C757-14A5-42C7-BDE9-39B609DAFC73
    C3E16104-D855-4F04-BFA0-18415A230398
    Right replacement door.
    Also note in the indentation for the outside handle the round bump out. This is like 66/67 doors that have the bolt for the front of the handle. Also on the inside the extra metal piece for that bolt. In the end of the door notice the location of the 4 holes for the latch compared to the left OG door. The door also has a hole in the inside front edge for a door check strap like the later doors.
    698CB256-4E2E-4D2E-BBC0-40C4694C1D84
    1E334361-F9CA-455F-86F8-FB5FBB4064A2
    AA3F16EF-4C47-432C-ADA5-E3529BA2818A
    C4D6CDF0-0314-47E8-8A37-1F4E797FBB70
    0B8D00C9-9559-4A79-9075-45DCC5816515
    Brazilian?
    Bus or door?
    It’s a German bus. This bus was repaired/repainted around 1986 and had been sitting ever since.
    You know those decklids that look like 58 but have a 66-67 latch on them. They are some weird Brazilian piece that you could in the 90’s
    I would guess the door to be Brazilian replacement origin.
    Yeah I remember seeing those deck lids.
    That is a possibility that it’s an aftermarket door for sure. I’ve never seen one like this.
    Ill look over the door some more and see if there are any numbers or signs of what it is.
    Maybe it’s from Columbia?
    New door bits for Tom’s 23Window ordered today. Thanks Gerson!!!B19D5253-369D-4210-BED0-5B00BD58AB20
    The bus was repaired before gerson was around I think. Definitely before he was making doors.
    This door has an old OG replacement part look.
