Home Forums Technical Questions 5 Wire turn signal switch
Viewing 4 posts - 1 through 4 (of 4 total)
  • DaKine
    I’m installing a new wiring harness in a 1965 bug. All is good except I’m having a time with the turn signal switch. I can’t find any diagrams w/ the wire configuration/colors that I have. Two prong flasher. Any help would be appreciated!
    Solid brown wire (looks like a smaller gauge then the rest -ground? not in any diagram)
    brown/white wire (not in any diagram)
    black/wht/grn with short jumper (assuming this goes to the two prong flasher and jumper to indicator on speedo)
    blk/wht (goes to turn signal-pictured)
    blk/grn (goes to turn signal-pictured)
    CCADFE09-7ED4-4D76-A927-3E8FED2F2355
    76572781-85CF-410D-90E8-7CF0599D7860
    A36CD5C6-3AD3-4FC9-8C61-5951CD69B79C
    Aaaaaaaa…Hey Franz?
    Black/wht/green goes to the flasher. The little blue jumper wire goes to the turn signal indicator bulb the other side of your two prong flasher should go to the fuse box.
    the brown wires are your headlight dimmer switch. One wire goes to ground, the other goes to the relay. If you have a floor switch ignore these wires.
    Thank you gentlemen! It’s working now 👍. In addition to wiring I had to take the handle apart and clean the contacts. Thanks for the help!
  • You must be logged in to reply to this topic.
