Home Forums Classifieds 2 liter motor for sale. Fresh build.
Viewing 7 posts - 1 through 7 (of 7 total)
  • MikeK
    New AS-41 Magnesium case, stoker clearanced, full-flow, sand seal
    New Scat 78 stroke forged crank
    Rimco Super rods with German SPS rod bolts
    12.5 lb German flywheel with pinned Kennedy stage 1 clutch
    Gene Berg Achiever crank pulley with broached pulley bolt
    Scat gland nut
    Gene Berg sump
    Mahle 90.5 forged pistons with Total Seal second rings. Deck is about .045” with approximately 9:1 CR. I can provide copper rings if your application requires lower compression.
    Scat 8mm chromoly head studs
    Engle 120 cam with SLR coated lifters
    Blueprinted and port matched 30mm oil pump and Gene Berg pressure relief, full-flow cover
    CB Performance 044 heads ported and matched to vintage Gene Berg manifolds with dual springs
    Solid rocker shafts with swivel foot adjusters
    All rotating parts are balanced from pulley to clutch by McCabe Motorsports. Case machine work done by Sportcar Service
    All German engine tin modified for dual carbs and merged exhaust
    Gene Berg carb linkage
    Rebuilt Weber 40 IDF carburetors with new, tall air filters
    New doghouse oil cooler
    Bosch 009 distributor and coil
    Rebuilt German Bosch alternator with oval badge
    Kymco 1 5/8, ceramic coated header
    Full flow filter adapter with exhaust mount
    Gene Berg style oil filler/breather
    CB performance billet alternator pulley
    CB performance thick exhaust gaskets with 12mm stainless nuts
    Engine is currently long-blocked and tin is fit and blasted but still needs paint. Some surface rust on the tin due to storage. Rockers and pushrods are not currently installed as to not put undue pressure on the cam during storage. Some light assembly and finish work will be required. All high-quality parts for a complete, turn-key motor.
    $5000
    Mike K
    719.205.7147
    Colorado Springs6BABAA05-89E9-4C70-A93B-E103332D7BA9E66FAA92-D95A-467D-BBA2-A026068B70FE612F45DD-C8DB-4331-B817-EFC186FBA8AEB4E6159C-0313-4CAD-A4AA-3B6F79E43F194516F0A6-C770-4C77-8B5C-F609640454C8
    New motor for Dan’s Mango?
    I'm at the age where "fuck off", "fuck you", and "fuck it" answer most questions.
    MikeK
    MikeK
    John Jones
    Moderator
    Good deal here for someone!!
    Knockin shit out!!!!!😎. One project at a time👍🏻
    MikeK
    Sold to Wayne in Florida.
    Thanks.
    Congrats Wayne!!! Fully detailed stroker…Hells yeah!!!
    Post up please…what’s it going in? Where ya at in FL? I did a 6 year stint in Freakville.
    Congrats on the quick sale Mike…👍
  • You must be logged in to reply to this topic.
