Home Forums KCW Completed Projects Ultimate Vanagon
Viewing 20 posts - 81 through 100 (of 544 total)
  • Franz
    The tubes and boots for the intake arrived yesterday. Check out those “intercooler tubes”. The muffler is stainless 2.5″ Magnaflow 3 chamber xl….offered as a performance part for chevy duramax diesel truck.
    Pat got a custom hose made for the Subaru power steering pump to vanagon. The picture kind of sucks, but you can see the pump is mounted backwards and acts as the tensioner, custom mount made by boxeer.
    Did some heli-arc welding on the thermostat housing/flange. This is much better than a rubber hose that can kink or get damaged. We had the intake flanges cut at a local water-jet shop. Looking forward to welding up next week.
    Lots of custom fab on this rig!  One part at a time!
    This mo fugger chugger is way to complicated. Should be a beast when it is done.
    Peet and Franz are widdling away at it…. They seem less than enthused about it..   No more Subi conversions, no more Vanagons..  Period.  At least not while I own the machine 😉  😉  😉  😉
    Bubba… Your POS lottery motor is junk..  no more vanagons, not even for friends.
    Pat got the billet sump installed. I made a couple more parts. Excited and frustrated. A lot of little things to this. Greg Blachon – Boxeer did not explain very well that this was going to be a re-engineer everything type of deal. I mean, the engine has been stripped to a long block and every fitting/connection/wire modified. I hope we can help others with the info provided here.
    shortened oil pickup tube 2.25″
    We need to order a 09-14 VW TDI lift pump  1K0906089A.
    Here is a good PDF from Subaru with a bunch of technical info.
    http://www.subaruforester.org/vbulletin/attachments/f160/343402d1466958538-subaru-diesel-ee-20-problems-scv-subaru-ee20-engine.pdf
    Spent yesterday welding the intake together. I have a little more to do today.
    Kleake
    ??? good work guys. How’ the hair holding up
    I welded in intake temp housing and finished the charge pipe this morning. Looks good. I’m happy
    I moved onto muffler fitment this afternoon. I had to shorten it a hair to make it fit the space correctly. Fully welded with flange and tip. I need to build some sort of support bracket to prevent it from rattling/breaking loose.
    Stellar work!
    Franz and Peet are pulling their long hairs out on this one.. 😉  😉   I know they will beat it…  I’m glad they got it….   😉
    Andym
    Looking real good.!!! I’ll stick with the gas engine. This diesel stuff looks like a shit load more work! Keep at it clean shop
    Do something
    I fab’d the muffler bracket today.  Made out of 1/4″ steel, it should be solid. Attached with two large t-bolt clamps.
    Andym
    Very nice!!!
    Do something
    Modernman
    Nice and clean looking!
    I like it all tucked up like that. Looking good. Hope that welding has been fun!
    Been working on the air filter situation. Trying to come up with something clean.
    Decided to go with this r2c filter. Supposed to be good for dirt. No oil for the dirt to stick to. I’m going to make a mount/shield for it to bolt into the corner where the cool air will feed it.
    Part Number: R2CCO10521
    https://www.kartek.com/parts/r2c-off-road-series-tapered-conical-air-filters-3-flange-8-tall.html
