Home Forums KCW Completed Projects The Goodrich ‘58 Westy
Viewing 15 posts - 1 through 15 (of 54 total)
  • Pat K
    I’ve mentioned this bus a couple of times in the  ‘58  Westy interior build thread. This one is in for a motor and trans update and a couple of other small things.
    No interior work required on this one, woo!!!558F4EE2-BB1F-41C0-A50E-BF2DC898C775B08BC084-DB90-4A4D-B15D-F93C079FCBA5BE88DC60-E955-46ED-ADB7-F71BBB8F52BC
    Engine tin is ready to go for the 1915cc that’s going in.  70305F7D-C792-4892-BFA9-FD403DC7CA2D
    Pulled the motor a couple days ago and removed the gas heater to make room for the dual carb set we’ll be running. 7EDFEBA9-9CE6-459E-A574-B6A734A90BC00D091E47-7807-41C9-8730-BFF516AE81EA
    We are also getting rid of a propane heater set up that was added at some point. A96D9B41-944C-4A15-8EC6-6E41DCF0FC826B5999B8-A461-4A64-8C46-6946DFBF5760
    Dang….sweet bus!
    Von_hansel
    Not one, but two pressed bumper Westy’s in the shop?!?! Very impressive! You typically do not see two at a show, let alone two in one shop.
    Curious, why is this one called the “Goodrich” Westy? Is it because it came from a town called Goodrich?
    Such an awesome bus- has the fridge, early Westy rack, propane stove, and the tent. I’m drooling over here lolz.
    Baja Mark
    Paul Goodrich? Old Bus I think.
    I hear that Goodrich was the guy who restored this at some point.
    Found a floor section to patch the hole left from removing the propane heater. Epoxy sealed and painted.  I would have to remove most of the camper interior to weld it in, so I’m going to seam seal in from the bottom side and secure it with a few screws. A4063F1F-65FF-49AC-ACBF-B0CA26BE10A7
    Also fit, sanded, and laid down the first coat of urethane for a interior floor patch.C5D0F5AB-4CA7-4B37-B508-35306C5D2EC8
    Cab roof panel were in sad shape, sagging and warped.8B353E68-163A-463D-9CD4-36745969F7BFD0FA4AA4-835B-4E12-896B-60A1640CD61A
    New ones just “slipped” right in.946842FE-E829-4ACC-BD9D-77543CC3E6F2A3CA3BF2-32CF-4BA9-AB57-E107828FB524
    Working on removing the trans now.FBCD69C8-C40C-42BE-BA48-28575488AAA3
    Von_hansel
    That makes sense regarding Paul Goodrich. It looks like his old PG/SG westy.
    Pat regarding the roof panels- you don’t have to brag 😛  Looks great! I look at mine at least once a week and dread trying to put them back in. I was told the ones sold by Wolfsburg West are easier to install than the Clara panels due to the WW being able to bend more.
    Glad to see this getting the love finally!!!!!!
    Proud and Stubborn 👍🏻
    More love. Finished pulling trans, sand blasted parts and and slathered then in shiny black.
    Bolted everything back together. Had a bit of an argument with a side plate stud. Drilled it out, tapped,  and heli coiled that little bugger.C6751A7F-C1E8-4D79-9E12-1A507F02ACD2D35D9F0C-6150-4179-B68F-474B476265E77F8536BF-170A-4234-BFF4-1A4B4C33C7EB
    All back together and bolted in.E69F1FD9-74D1-4772-8352-515854624BDB827477AB-E8F6-48CA-8567-3A5246D47D98
    Stacking the engine yesterday. Pierburg fuel pump, new oil cooler, og generator stand, and Bosch cast iron 019 rebuild.
    576F5295-EEB8-4A20-B268-004B0960ADD9
    image023C80A0-0431-43E2-9514-8FB40D2849AA
    The carbs and manifolds received alodine treatment.
    32C71765-7519-4CE9-BEBC-CE1ADC12280E
    Assembled 019 distributor with new parts
    C1D30BCA-9DAA-4722-B8DC-3C9CE7414C7E
    Getting the “treatment”!!!!!!!!!  Maybe this next week or so we will see a new mechanical breath of fresh air coming out this old mans tailpipe!!!!!!
    Ya man, this bus had all sorts of mechanical problems. I could hardly get it 1/4 mile to the gas station. I can’t believe Lind drove that thing to California and back last year…
    The a1 sidewinder arrived yesterday. I set to work on welding flanges and painting them in high temp ford grey. Ready to install them and run this engine.
    75E8E25D-AA3C-4A96-8439-2D0D605F834FCEF578A7-2814-49D0-9C8E-0335AB4AE3BB
    Awesome blossom, 2 PGSG. Buses to take out!   What photo shoot.  Using those buses will feel going back to 1958🙄😁😁😁😁
    She’s a runner! Just finished dropping the break-in oil out.
    30A78EF7-7CE8-4232-A4CD-D31BE2B3C4D8
