…that fastback job…it sucked.. maybe one day he will fix it, until then it’s dead and once he fixes the air flow to the radiator, no air flow, no cooling. Im sure he can find a guy working outta his garage who can fix it..
On a a positive note!!! Maddie’s van got delivered this morning! Dam nice van! I got a nice 2.5 engine here, waiting on rest of the parts.
Here’s another one we knocked outta the park.. ‘60 camper, got a nice 2.2 in it. Required zero cutting or mods.. I love it! He got a 3:44 r&p in his new trans with redux boxes. Drives very nice!
You fucking Rock Andy…. 😎
Thank you Andy for getting that turd out of my front yard… 🤗
I’m sure it will be back…. Aren’t you and that girl shacking up ????? 😎 😎
Heres the ‘56 single cab we just finished a 2.2 subi swap using dual throttle bodies from cb performance. I cut the stock subi intake down and use the stock injectors, then cut some type 4 dual throttle body manifolds in half, welded em up and done!
Defiantly wanna do carbs, but feel it’s a waste of carbs on a subi…kinda backwards motion.
Dual 40mm throttle bodies on a subi!! Seems like it has a lot more balls. Who knows, ass dyno…
Ill try to load a video of it running.
This Single Cab with a mid-mount Subi was at Dallas VW Dub Splash today. Pretty sweet engineering on this rig.
Kinda weird I had to lean the tune out some.. gonna install o2 sensors off each head so I can see each side.
Now if I had a small ball shifter here I could drive it..
Video for everyone!
Hi Andy
i am very interested in this setup fir a project I have here in the UK….is this something you could offer as a kit?
what ECU are you using…..do you expect it to run as good as the stock Subaru setup?
You want a Dual throttle body set up?
I use microsquirt for the ecu. Stripped down basic motor controls.
Doing kits sucks, but I can do it.
Yeah… unfortunately.
Has had some benefits though, hooked up with her cute friend 😉👊🏻
Excited to see what you do with it Andy!
Got the single cab out. It’s a fucking rocket, dual throttle bodies defiantly helped with performance. It’s a neat set up…something id do on my own car. A beetle would look cool with this set up.
Up next, vanagon, sandrail, beetle, another type 3, couple bays. And a long as rusty bus…
Built another set of 4 lug cut drums to disc kit. Same trick I’ve done a few times, cut the center of a 4 lug drum out, drill/stud it Porsche, then Chevy s10 Truck rotor.. still surprised nobody else has done it yet. It’s cheap to do!
I don’t get it.. 😎 You cut that drum down into a rotor??
