Home Forums Bullshit Subaru bullshit!
Viewing 20 posts - 441 through 460 (of 490 total)
  • Andym
    Heres the ‘56 single cab we just finished a 2.2 subi swap using dual throttle bodies from cb performance. I cut the stock subi intake down and use the stock injectors, then cut some type 4 dual throttle body manifolds in half, welded em up and done!
    Defiantly wanna do carbs, but feel it’s a waste of carbs on a subi…kinda backwards motion.
    Dual 40mm throttle bodies on a subi!! Seems like it has a lot more balls. Who knows, ass dyno…
    Ill try to load a video of it running.
    06087B3B-0132-4D02-B8A2-6214DF773EA5
    Do something
    mdubg
    This Single Cab with a mid-mount Subi was at Dallas VW Dub Splash today.  Pretty sweet engineering on this rig.
    5uDpQ2vrRGaIDEA06kJ6oQlYoFzWjBRTSKqqOraZ0sjA9be8KU38SZiHpm1sPY%rxgajkhgNIlS3OBAeanPPT4uwhsaR0PilSG+N8i+qMBpfxQ
    Dual 40mm throttle bodies on a subi!! 06087B3B-0132-4D02-B8A2-6214DF773EA5
    That looks real nice Andy. More air and more air speed I bet.
    Andym
    Kinda weird I had to lean the tune out some.. gonna install o2 sensors off each head so I can see each side.
    Now if I had a small ball shifter here I could drive it..
    Video for everyone!
    Do something
    curbo
    Hi Andy
    i am very interested in this setup fir a project I have here in the UK….is this something you could offer as a kit?
    what ECU are you using…..do you expect it to run as good as the stock Subaru setup?
    Andym
    You want a Dual throttle body set up?
    I use microsquirt for the ecu. Stripped down basic motor controls.
    Doing kits sucks, but I can do it.
    Do something
    Thank you Andy for getting that turd out of my front yard… 🤗
    I’m sure it will be back…. Aren’t you and that girl shacking up ????? 😎 😎
    Yeah… unfortunately.
    Has had some benefits though, hooked up with her cute friend 😉👊🏻
    Excited to see what you do with it Andy!
    Andym
    Got the single cab out. It’s a fucking rocket, dual throttle bodies defiantly helped with performance. It’s a neat set up…something id do on my own car. A beetle would look cool with this set up.
    Up next, vanagon, sandrail, beetle, another type 3, couple bays. And a long as rusty bus…
    Do something
    Andym
    Built another set of 4 lug cut drums to disc kit. Same trick I’ve done a few times, cut the center of a 4 lug drum out, drill/stud it Porsche, then Chevy s10 Truck rotor.. still surprised nobody else has done it yet. It’s cheap to do!
    A339C64D-E9E3-4C40-B08A-885E31127286797B7A14-1165-4929-A2FC-815785AF8E10
    Do something
    I don’t get it..  😎  You cut that drum down into a rotor??
    Andym
    Yep!
    FBFDC2F0-914B-49B9-8695-B0FDFC0B59F7DEBEAE97-52EB-4610-96F2-80A6D5A29F90
    Do something
    ahh I see… Thats an s-10 hat you weld to the turned down drum???
    Andym
    Yeah it’s an s-10 rotor, the vw drum/hub is just turned down and slid inside the hat. Tight as you can get it without press fit and without being loose and sloppy.
    Do something
    Baja Mark
    Do you reckon this would work on Bay Window disc spindles Andy?
    This is what oldspeed(Russell) has been doing for 30 years.
    Andym
    Mark, yeah this would work with anything.
    Franz, I thought he used Porsche hubs? I’ve never seen his kits in person.
    Do something
    Andym
    Check this bad motha out! It was a part of the northeren California fires from last year. Got lucky as you could get.. anyways, it drove home yesterday.
    Anyone need a great running 1776 type 3 engine?? That’s what came out of it.
    now it’s a 2.5 subi, I rebuilt the engine. He drove it home 300 miles yesterday.. zero issues!
    8712FB6E-8DF3-4811-84E0-3770D2C9877F
    Do something
    Good looking car! Going to be a sleeper.
    Jeremy
    Andy, I have some Subaru questions. Can I email you personally?
    curbo
    Hi Andy
    Please could you possibly email me directly on a dual throttle body kit?
    mark.curbishley@btinternet.com
