Home › Forums › KCW Completed Projects › Sailing Bridges ‘52 single cab
Made good progress on this yesterday. Finished pulling all of the wiring harnesses to their locations.
Modified domelight harness from a bus to a single cab. Domelight installed.
Looks like we need to source 3 special clips to secure the dome light wire to the pinch weld seam along the back of the cab.
Passenger door window mostly assembled, need to order a couple of small bits to finish it up but that won’t hold up install.
Rounded up parts that need to be sent out for chrome.
Semaphores sanded and prepped for paint.
Pod is going in today!!!! Some glass is going in today also… 😎 gonna be a good week for this truck… 😎
Oh….. I haven’t seen a wiper motor or shafts or rods for the shafts….
I was chasing threads on the emblem yesterday and one broke of studs snapped off.
Welded a new one on. Body working the front side. Respray later today
JJ is knocking out pod assembly. Looking good!
Pass door window in. Front and rear window seals on, ready to go in.
Kick ass day yesterday….. all the glass is in…. door frames in…. pod assembled and wired in.. Franz located my wiper stuff… so I will get that in today also!! I’m about to repaint that emblem…. I think we will get onto those reducs and check shit out and start prepping for trans assy!!!!! 😎 The beam already looks rebuilt.. It’s just gonna slide back in there….. 😎 I’m gonna start putting pedals together today too….. 😎
Those correct tail lights look awesome.. and those late one’s we took out will look really good in the Pamper… 8-0
JJ kicked me out the dirty shop. Couple pics from the drive over.
Seals in.
Tearing reduxs down.
Lookin so good !
hell yea! you guys are the best !
Finished redux tear down this morning. Rounded up what needed blasting.
Going to prep everything for paint next.
Epoxy sealed axle tubes in the sweet spots you can’t reach with just one session.
Sealed and painted. Trans assy tomorrow.
this truck is in high gear!!!!!! 😎 Going to be a functional truck in no time!!!!! easy peizey!!!!
Theme for today was transmission.
Had to pull some parts from your old split trans. Had to hunt some part from the stock pile.
Clearanced nose cone for the lollipop adapter.
Seamless axle boots by Franz.
Coming together.
Realized backing plates I pulled from the spit case trans this morning would not work due to the donor redux boxes have been switched to later outer half’s. Backing plate fitment issues.
We had a set of later backing plates sealed and painted, score!!! We will need to order some brake parts to accommodate the later backing plates.
Transmission all together and sealed!!
The efficiency of KCW never ceases to amaze! You guys are one well oiled machine! Truck is looking perfect 👌
Well, Somebody has got to slow those Guys down! Guess I’ll head over with some booze and distracting behavior!!! It Is the weekend ya know!! 😉 😉 🙂
Thanks Josh!!!! Thanks a ton.. Thats why I say “It’s the greatest place on earth to get a Volkswagen fixed”… 😎 😎 This is all we do, day and day out, there is no variance, and we have fewer distractions than most… 😎 😎
Love the look of the back of this truck!!!!!
