Home Forums KCW Current Projects Sailing Bridges ‘52 single cab
Viewing 25 posts - 101 through 125 (of 226 total)
  • Pat K
    Theme for today was transmission.
    Had to pull some parts from your old split trans. Had to hunt some part from the stock pile. FBAEB350-CA92-465B-8C5B-8B7AEA706FB4741FD39D-7725-4EE8-ACCE-F908411CAF73CDF4EEDA-2847-44E8-80AA-404082F2AC02
    Clearanced  nose cone for the lollipop adapter.C4326626-0F16-4665-A953-B8CCD254DE1D160DE3C7-D66B-4ED5-BDD2-6EB105D15F1D7CA7FCCD-A77D-46A5-B15B-EB1F2B3B0EBE
    Seamless axle boots by Franz.DFC34640-7E09-4D15-BA41-9121101758D5
    Coming together.753F63FF-3AE2-4617-9539-F70E22AA1DD64E6E9293-9535-4A90-8E82-A6CA75945A4F
    Realized backing plates I pulled from the spit case trans this morning would not work due to the donor redux boxes have been switched to later outer half’s. Backing plate fitment issues.7D97E741-FFA2-491F-9628-BAC0A5927D6A74D58AB3-687D-400B-B3A4-DCB93B04ED9B
    We had a set of later backing plates sealed and painted, score!!!  We will need to order some brake parts to  accommodate the later backing plates.
    Transmission all together and sealed!! 1A0C8744-A18F-406A-BA56-074F9069555FEC1EEA53-1A3C-4CFB-B556-9D3A076A04522693A0AC-0107-434E-8986-C80DD14BF261
    The efficiency of KCW never ceases to amaze! You guys are one well oiled machine! Truck is looking perfect 👌
    Well, Somebody has got to slow those Guys down! Guess I’ll head over with some booze and distracting behavior!!! It Is the weekend ya know!! 😉 😉 🙂
    hahaha
    go get em Rusty !
    Thanks Josh!!!! Thanks a ton..  Thats why I say “It’s the greatest place on earth to get a Volkswagen fixed”… 😎  😎  This is all we do, day and day out, there is no variance, and we have fewer distractions than most…  😎  😎
    Love the look of the back of this truck!!!!!
    DSCF9249
    Pulled this off the dolly today. Started cleaning out cable tubes. 89591AC1-1185-48C8-A5BD-C0F2AFCFD293771FD423-45E9-4E31-A279-91EBC34182700EF56A0C-4085-4F4E-B20C-3808002F448A52D2ACD1-5DAF-4919-9FD0-AC898BB69BD8
    Them dirty ass cable tubes… Clean cable tubes, make for smooth operation of cables… 😎  Pats kicking it’s ass… One part at a time… 😎  😎
    What cleaners are you using to clean the tubes?
    Also what method? Like what are you shoving through it to get them clean?
    My favorite John Jones quote:
    sanding sucks my balls and there is no need for any pics.. 😎
    ^^^ Stiff wire, solid throttle cable works great,  small piece of microfiber towel, break parts cleaner.
    Squirt a bunch of brake clean in the tube, push the wire through, bend a small tight hook on one end, bait it with the microfiber towel, pull from opposite end of towel and hope your karma bank is full so nothing gets stuck or breaks. 7BA21043-AF33-4F9C-A9B7-3BE9585D0A06
    Finished cleaning cable tubes this morning. Break hard lines next.CAFDB243-DD14-423D-A147-A4A9DA410920
    Thanks Pat. Uh yeah the Karma thing. Hahaha. That leads me to the next question
    So any advice on how to get a cable out that’s stuck in the tube. Not sure at the moment which one but it has the sheathing. And it’s stuck. I’ve sprayed all kinds of shit in it and tried pulling it out with visegrips clamped to the end and pushing it out with a solid rod.
    Also it’s a deluxe bus with belly pans that are in good shape and do not need to be removed.
    delete…
    Balls! Must be choke cable…That doesn’t sound like much fun ahead!🤭
    Assembly is still in forward motion!!!
    DSCF9288DSCF9273
    unk
    I am amazed that this is going to be a work truck getting all scratched and dented.    That is nuts.
    Break hard lines yesterday. We’re decided to run a dual circuit MC on this one since it’s going to be a work truck.
    Welded in a stud for a tee to the front brake  circuit. Need to run both fronts off the residual pressure valve because we’re not running disc brakes.
    I will m finish up the last couple lines when the parts arrive. B202E968-07C0-4E1E-8554-2A7067FC4BF0DCC453FE-273E-45AA-B4C1-043ECA34DFB14C33C01B-B965-4909-A467-892F631D63D91596E8AC-68C3-40F6-BDDF-817729C7E3B7
    Trans and front beam installed yesterday. My dumbass “test fit” the trans. Don’t forget your shift rod boys. Doh!!!62B29CC4-152B-483E-976D-8B477C3F4B84F22D36D4-8342-41F2-BDBB-EC8B32F51CE372C938B0-4918-49FB-9563-97EE53E3945DA59E6091-2145-4DE2-8EB7-D7A2711F9382
    Rounding up steering gear this morning. 1478D7DA-5CB0-444D-BB32-75B334B4E5C0
    This truck is getting close!!!!!!!!!!!!!!!    I think the engine tin and what not should be here soon.. We got an A1 and I think Franz ordered you a brand new type 4 cooler fan shroud yesterday!!!  We must finally be out of good one’s!!!!
    I think it has come out better than anticipated…. and I imagine, it will not be a shop truck… Probably sit in the warehouse right next to the other Barndoors…. 😎 😎  😎  Quite a collection KB has assembled!!!!!
    Few more bits and pieces on yesterday. Gas, break, and clutch pedals all in.  Steering box and shaft as well.6A2E6287-3E3C-4F1A-94D6-EAA4DB3CBC092A2BBD95-EFE4-489A-B043-04A4393F8037
    Shift rod and hockey stick don’t quite line up. 5DDD54F2-50D9-4FC1-8F61-AF6CBA7387B7
    Pulled trans to clearance trans frame horn tabs where there hitting the transmission case.  Hoping this will solve the issue. 343FDA46-76B6-4E78-8DEE-EEBB551FB9F4
    Where’s the 25 hp and crashbox??
    sitting in a box where they should be if you really want to drive it much… sure a 25 will “work”  but it would suck..
    Pats been playing with KB’s small ball all day….. 😎  The shifter is being a whore …8-)  well get it… 😎
    DSCF9330DSCF9319
    Those small balls are a bitch hahaha I don’t know what you dealing with there but….We been adding some material to top of cup on shift rod with TIG and then profiling it down…only need like 1/8” and keeps all in there good!
    Came in Saturday morning and finished up the shifter install. Total pain, but small balls need lots of love.
    Parts have been stacking up for this one. 8B019473-69DB-46F8-82E4-3932C651F7580E2357A9-0C0A-4355-AD2F-003C3D5099DD21FB1524-BB4C-43FE-ABDE-194040DDDAA7
    Going to finish the brake system today. Unstuck, blasted and rattle can painted some OG brake  hardware. Fresh German rear drums epoxy sealed, paint when dry. Assembling front wheel cylinders now. 97104F15-6FDB-4017-A386-C720EEAA6D94783A8755-C032-45D3-93A8-F1FA7CBE20DC9A3D380C-CFF7-4AA3-873E-E35C04BFF81254923D96-19BF-4ADE-958D-849EB7FAD448
    BD wheel cylinders..
    DSCF9351
    Some re-chromed trinkets arrived this morning.
    DSCF1073
