Home Forums KCW Current Projects Robert’s ‘66 13 Window Standard
Viewing 15 posts - 16 through 30 (of 197 total)
  • Rustabus
    Vents are definitely the biggest eyesore, are the wheel wells going back to stock????? It does have a look with them cut!!!😃😃😃
    AZbusbarn
    Good question John, I don’t really have a fresh on, how does that single port look?
    vents are the main thing on my mind, I’d like to get a big motor in it some day I just don’t have a good case right now.
    wheel wells are staying cut, that is gonna be my Shasta bus if I ever get enough time off work maybe 2024 will be my year.
    AZbusbarn
    Does your upholstery guy want to do those front two seats?
     Funny..  probably..
    that motor has a 6v flywheel and clutch👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻…
    AZbusbarn
    Damn yeah I’d like to get away from the 6v….. maybe just a flywheel and clutch? If that motor looks halfway decent, just to get it on the road but if that motor is shot then maybe I can find a motor
    Audrey Jones
    612E7D08-5E89-4AB0-9F34-7AA1ED0B486883D483BF-4C6D-4542-85DF-51713691460EFound a couple vent windows and a stationary window in the trailer that should work for ya! ✅
    Never make somebody a priority who makes you an option.
    AZbusbarn
    y’all have an awesome innovatory!
    Conversion flywheel from DPR?  Hummm.  Guess I’ll look at it.
    if you want to send kits from WW I can get Doug to do the labor I’m sure..  but you could do that yourself really. Save money 😉.
    Vents!
    w
    Audrey Jones
    For a L555 Titan red you get mesh gray interior so I see a front seat cover kit and the horse hair pads too on Wolfsburg West – if you want to order those for us I can talk to Doug about it 👍🏻
    https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=221881002EGYY
    AZbusbarn
    Perfect thanks so much, I’ll get them ordered and sent to kcw
    If you want a new wire harness, get that too👍🏻👍🏻👍🏻  I don’t see a turnstiles final switch?  You boy 👦
    one side in!!!!  Time to celebrate!
    2DA7F121-763A-41CA-9592-FDFC826E295BWant all the extra holes welded, like the old scoop holes?  The holes around the wheel wells??  That’s how they cut en out?!!  Drilled a billion holes☹️
    AZbusbarn
    Looks awesome John! Yeah fill those holes up! As for the wiring how’s that harness look? If it’s pretty intact then let’s just use it….
    I can make anything work…. It’s just how nice does Robert want it😎.  I’ll run some wires up to the steering wheel you have to touch together to get signals…😉😉😉😉😉😉😉
    gonna knock out these other vents this morning..,  then???  Want me to start changing bulbs?  Sort some wiring?  I’ll simplify this late shit and get rid of emergency flashers..
    want the seat frames torn down and blasted and painted?  Or just cover it?
    getting after it !
    nice work John
    AZbusbarn
    I don’t want it tooo nice 😆 I like all my junk rough but reliableish… let’s just cover the seats, sort the wiring best you can. Working blinkers are over rated
