Home › Forums › KCW Completed Projects › Pete's 58 Lowlight Karmann Ghia
Love your car Pete…I really like how you just keep improving it little by little. I do the same with mine but yours is WAY cooler! ๐
I agree…. really like this Ghia. and like Pete’s style… ๐
Honesty can potentially harm your relationship ๐ข
Had some minor sputtering once the car was warm when taking off at low idle.ย After checking valves, fuel delivery, and points/condenser/timing/distributor/coil/plugs, I made new wires.ย Seems to have done the trick.ย I changed the routing so they don’t take that hard turn between the manifolds and shroud anymore, so now they’re shorter too.ย I suspect I probably fouled a wire from handling them repeatedly during maintenance.ย Went with the same Lowbrow 8mm cloth wire, this time in black.
Y’all have a good weekend.
It’s not the wires. It’s the lack of a supercharger.
July 14-15, 2023
November 17-18, 2023
www.germanaire.comMy car has the air vent baskets in the nostrils, but had been missing the flat screen that goes over them. ย I found a solid pair that were a little grungy and clean them up. ย I had been wanting to try DIY electroplating so I gave it a go.
Soaked the screens in straight vinegar for several days to remove the crud.
After soaking, before wire-wheeling:
I used two pieces of zinc, vinegar & salt, and a cell phone charger to make a zinc electrolyte solution. ย After that I connected a copper wire to the screen, then the negative side of the cell phone charger to it. ย Positive to the zinc bar. ย Placed it all in the solution and plugged it in, letting each screen go for about 45 minutes, while turning it every so often. ย Below the solution is cloudy from the bubbles coming off of the screen, which is the zinc being pulled to it.
The screens were sort of a flat gray color when done, and a little splotchy. ย A very quick pass with 000 steel wool put some shine on and evened them out.
For a first attempt I have no idea if I did this right. ย They look ok and appear to have a zinc coating, so I guess time will tell if it holds up.
Details๐๐๐๐๐๐
More DIY zinc electroplating.ย I have a Pre-A style oil breather that uses a spring to connect the breather to the engine block.ย The spring was lightly coated with oil when I bought it so I knew it was raw spring steel, and over time it has developed some flash rust.
This time instead of a vinegar pre-soak I dipped it in muriatic acid – it was cleaned and etched in a matter of minutes instead of days.ย Neutralized with clean water, then used the same cell phone charger, zinc/vinegar/salt electrolyte, and zinc ingot bar to plate it.ย 20 minutes total, rotating every 5 minutes for even coating.ย Light polish with steel wool when done.ย Seems to be a easy way to refresh parts without having to send them off.
Plating process – negative side of charger connected to part that’s being plated, positive to the plating source (the zinc ingot).ย The bubbles are the zinc being attracted to the spring:
What the part looks like when plating is done.ย It’s dark b/c it’s wet; if it were to dry it would be lighter with a flat matte finish.
And after a light polishing with steel wool.ย It doesn’t take much….it’s more like a few passes of wiping it with the wool.
I also made some nickel and copper electrolytes, but have yet to try and plate anything with them.ย I’ve toyed with the idea of re-plating my copper Hurst shifter, but I’d hate to screw it up.ย I’m on the hunt for a cheap broken one to try it out on.
Hell Yeah!!! DIY Awesomeness!!!!๐๐๐๐๐๐๐๐๐๐๐๐๐
Sunday cruise for some froyo and a large hot dog.
Killer Ghia. It photographs really well.
