Home › Forums › KCW Completed Projects › Pete's 58 Lowlight Karmann Ghia
Nice work Pete…hope you get to enjoy some cruising this weekend. Weather looking good down there?
Drive today?
I seem to have a hazy memory of cleaning that original fuel line out with a clutch cable on a drill….I know we didn’t swap hardline. Tank only got a swish out…don’t think it looked bad tho? Stock old 36 would sip fuel through a pinhole and be happy as a clam hahahhaa!
It’s running beautifully, but not after a weekend chasing electrical gremlins. It was brutal….was ready to throw a car cover over on it and let it sit for a few weeks. Had a bitch of a time just getting it to turn over. Cleaned battery ground, trans ground, starter connections, etc. Thought maybe I had a bad ignition switch, but finally got it turning over nicely.
Plugs were very foul so I took out the 60 idles and tried 55’s, was good but still had that slight flooding/bogging feeling between 2500 and 2800 rpms at 1/4 throttle. Put in 52.5’s (with the 122 mains) and it’s perfection at full throttle, 1/2, 1/4, etc. cruises nicely, not a single pop from the carbs. Seems to have more idle mix adjustment with the 52.5’s. Didn’t mess with the wideband….don’t have the patience for that at the moment.
Thanks Franz.
I liked the look of the cloth spark plug wires I had originally bought, but didn’t like the reviews. They were 7mm, and prone to arcing. They just felt kind of cheap too.
I found an 8mm solid silicone core, USA-made cloth wire, sold by the foot, from a motorcycle parts company called Lowbrow Customs. So I decided to make my own. Added bonus is I can cut each one to an exact fit around manifolds and whatnot. 8mm wire on left, 7mm pre-made on right.
Hell yeah times 2…. 😎 Old cars can be frustrating sometimes…. Patience… 😎 Happy for ya Peet!!!! 😎
Lowbrow wire is good. I have used it before. Glad you got it running well!!! Plus it makes since why it ran good on the test stand
Just because. 🙂 Have I ever mentioned that Franz nailed this build? 🙂 I freaking love it.
Pete skip the wideband and just work from the plugs. Run a touch rich to keep your engine safe and cool in your hot humid climate
Germanaire here we come!
July 14-15, 2023
November 17-18, 2023
www.germanaire.comNo issues with the shortened filters and the springs?
July 14-15, 2023
Nope! 5/8″ removed from the filters did the trick, springs clear with an 1/8″ to spare. K&N also makes a 4.5″ x 7″ oval filter that is a little less than 3″ in height so I have something better than just the foam insert.
What fuel pump is there now?
