Home Forums KCW Current Projects Parkway projects
Viewing 15 posts - 1096 through 1110 (of 2635 total)
  • Rustabus
    Totally your call! Iโ€™ll just cry like a little girl and hand over Hundies!!!! ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
    Hell yes ! you gotta be stoked Rusty !
    I Am!!! Franz called me and said that my Bus was WAAAAAAYYYYY more perfecter than he thought and it will be all finished up this AM!!!!!!! ๐Ÿ˜‰ ๐Ÿ˜‰ ๐Ÿ™‚
    I agree, forget the oil leaks and letโ€™s push this rig outside.
    Iโ€™ll shut up now!!!! Keep fixin it!!!! ๐Ÿ™‚
    I assume you want a tune up, valve adj, and head torque?
    Yup! All that stuff!!! ๐Ÿ™‚
    Jeremy
    6735035E-10BD-4602-BADA-F24B54050723[/quote]
    What is that interesting looking puller near the brake kleen used for?
    Dario
    I think you guys should cut and buff it. Would look awesome to see a big shiny marshmallow in your vacation pics!
    โ€œLife is a waterfall,
    Weโ€™re one in the river and one again after the fallโ€
    Has anybody seen one of these? What does it do? Maybe a bleed oriface to prevent heat soak flooding?
    0B9611A4-D70D-4F73-8F0B-5B79C497731E
    I ainโ€™t paying the guys to pretty up my Rig! They gotta build not buff!! ๐Ÿ˜‰ ๐Ÿ˜‰ ๐Ÿ™‚ ย Donโ€™t tell me that scabby part was on my Bus!!!!!!!
    Thatโ€™s some other junk I was messing with today. Unusual.
    Come-on! Letโ€™s polish white lightening. It needs it. Looks like caca currently. You barely wash it! Could look like an og cream puff.
    Plus you know jj wants to.
    Cโ€™mon! We kinda buffed some of it like 8 years ago! ๐Ÿ˜‰ White Lighning needs a deep clean and buff for sure, also needs new window and door seals all around!! Mechanics first, pretty after!!! ๐Ÿ™‚
    What is that interesting looking puller near the brake kleen used for?[/quote]
    Rear wheel bearing puller.
    Rusty.
    Pulled your engine yesterday and replaced the rear main seal that was leaking, new trans seal also.
    Put the engine back in. Pulled rockers and torqued heads, adjusted valves, fresh oil in, new fresh air tubes on.
    Headlight relay was bad, replaced that with a good used one, now you have high and low beams.
    Horn was junk, replaced that.
    Lubed the front end and adjusted front breaks.
    Made up a new muffler hanger, your was missing.
    I will finish up rear breaks when they arrive on Friday.
    Handing this off to Franz for the tune up.ย 344B23B6-F180-4797-B18C-0C472F298102
    EE94880D-BB67-403E-A9F6-4DF2E0B5D808
    8D460193-BA32-43CA-923F-90AFFC85BA4E
    E1ED7CFC-AAAA-4F4E-929D-61CFF18E3BE7
    68F09F8C-5F0F-4B5C-B137-C825C2F738B7
    Wooooo Hooooo!!!!! Super stoked to have this Rig all dialed in again!!!!!!! Yeah!!!!!!!! ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
