Totally your call! Iโll just cry like a little girl and hand over Hundies!!!! ๐ ๐ ๐
Hell yes ! you gotta be stoked Rusty !
I Am!!! Franz called me and said that my Bus was WAAAAAAYYYYY more perfecter than he thought and it will be all finished up this AM!!!!!!! ๐ ๐ ๐
I agree, forget the oil leaks and letโs push this rig outside.
Iโll shut up now!!!! Keep fixin it!!!! ๐
I assume you want a tune up, valve adj, and head torque?
Yup! All that stuff!!! ๐
I think you guys should cut and buff it. Would look awesome to see a big shiny marshmallow in your vacation pics!
โLife is a waterfall,
Weโre one in the river and one again after the fallโHas anybody seen one of these? What does it do? Maybe a bleed oriface to prevent heat soak flooding?
I ainโt paying the guys to pretty up my Rig! They gotta build not buff!! ๐ ๐ ๐ ย Donโt tell me that scabby part was on my Bus!!!!!!!
Thatโs some other junk I was messing with today. Unusual.
Come-on! Letโs polish white lightening. It needs it. Looks like caca currently. You barely wash it! Could look like an og cream puff.
Plus you know jj wants to.
Cโmon! We kinda buffed some of it like 8 years ago! ๐ White Lighning needs a deep clean and buff for sure, also needs new window and door seals all around!! Mechanics first, pretty after!!! ๐
What is that interesting looking puller near the brake kleen used for?[/quote]
Rear wheel bearing puller.
Rusty.
Pulled your engine yesterday and replaced the rear main seal that was leaking, new trans seal also.
Put the engine back in. Pulled rockers and torqued heads, adjusted valves, fresh oil in, new fresh air tubes on.
Headlight relay was bad, replaced that with a good used one, now you have high and low beams.
Horn was junk, replaced that.
Lubed the front end and adjusted front breaks.
Made up a new muffler hanger, your was missing.
I will finish up rear breaks when they arrive on Friday.
Handing this off to Franz for the tune up.ย
