Home Forums KCW Current Projects Parkway projects
Viewing 20 posts - 1341 through 1360 (of 1369 total)
  • Franz
    Assembled 2276cc short block and figured compression @ 8:1 with . 110” deck and 60cc heads. Fk8 cam advanced 4 degrees on strait cut gears.
    Dark painted pushrod tubes don’t reflect heat back at the cylinders. 😉
    EB0DD818-3362-4B4D-90E9-39DFC78CB14D
    Good looking vintage speed engine of Erik Thompson’s. Okrasa engine with Porsche Zenith carbs. I modified the fan shroud and Porsche linkage for him last year. Going into a black oval window beetle.
    D282D4DB-3F5B-44ED-8DEF-4A987599B31E
    Dario
    Dark painted pushrod tubes don’t reflect heat back at the cylinders. 😉<noscript>EB0DD818-3362-4B4D-90E9-39DFC78CB14D</noscript>
    🤦‍♂️does it add horse power if they’re dark red ?! 😎
    Vwsarent4hippies
    Good looking vintage speed engine of Erik Thompson’s. Okrasa engine with Porsche Zenith carbs. I modified the fan shroud and Porsche linkage for him last year. Going into a black oval window beetle. D282D4DB-3F5B-44ED-8DEF-4A987599B31E<noscript></noscript>
    (‘58 beetle)
    Nice work, Franz, it came out very nice!
    All Erik, I just did the one little thing.
    Erik’s done a nice job with the vision for his engine.  I really like it.
    Parkway fun. Chopped out the pass bulkhead for a swivel seat addition. 7C6DC000-135F-4A9F-BA90-0B2BB17F5B35
    Cut up some strap and and used 4-8mm bolts to make a seat base to swivel adaptor.6D42BCA0-1BD5-4576-8A0F-8A1F9766201DB55BCF1E-C334-423A-BDEA-FF745A49FC5EWelded the adaptor to the base and touched up paint.11E75C1F-A6F7-485C-A166-5D66E7FFC86F41FA8638-FF4E-41E4-A292-83A72B4A5E2F
    Bent up a piece of 3/4” tube and sheet metal for a b-pillar support.73391407-4C46-4488-85BB-55F1CC4B454732B073EB-8F78-4384-AEDA-8157C99ABD3F72929CDB-D485-416C-B969-56E79BA7454ETouched up with some sweet Krylon.5E08DEA4-751D-47C0-ABE7-CF85E940C6B34BC1CF67-2DEE-4FB3-AB8F-26A5B6B4373C
    Krylon….nice.  Giving that Baywindow the respect it deserves.
    Jokes aside you made clean work of that mod!
    More late night parkway love for this little blue late model standard last night.
    Pulled motor and replaced all trans/engine mounts. 5E58A1BF-C2A0-4816-8DD4-3E3703ABC8C4
    Front shocks were incorrect, wrong length. New correct shocks installed. These bushing are always stuck.8826972C-A477-4137-8151-7DDB83D7B0783549B7EA-9834-4E43-8359-FB3ABE7B17F5
    Also pulled rear drums to free stuck adjusters. Adjusted all brakes, front wheel bearings, clutch. And a few other little thing along the way.
    All back together, test driven and ready to go home!20223EF4-3F7B-4AAB-8533-24A7A64A95B2
    I like parkway projects more now than ever…. quick in, quick out, quick pay… 😎
    This bus showed up week or so ago.  Pulled the motor out and sent it off much need rebuild. 164AE860-F0C8-47B7-9652-24B5999FBE2A
    Sand blasted all of the OG VW tin we like to use. 46BFDB84-E4FA-45A3-A49F-FB1C05B6840A
    Always some cracks to take care of and a couple of extra holes to fill. AED76D32-14FF-4868-9191-3C60A79D4F7447CD2D13-7ADC-4763-87A8-FFE0DE6658DA
    Gettin there!87DD580F-F58D-44D7-B713-34226B715EFC0896BF10-802C-4E74-9C78-FBCC4314FEE9
    Lovin the Parkway Projects!!!!! Can’t believe how many Random VW’s not in our little group show up all the time!!!! 🙂
    Yeah, this one is from Montrose and is used for ski trips and stuff. Going to build a nice little stroker for it.
    Erik_T
    Thanks Franz fro your help on this engine build!  It turned out great, just what I was hoping for.
    IMG_6979
    1958 Outlaw Beetle
    Looks great installed! Do you think the zeniths are smoother running carbs? More power? Where did you get the manifolds?
    I’ve only messed with WW solex copies once, they didn’t seem all that impressive.
    Weston wenching on a 79 bay today. Oil cooler seals.5D83B30D-BFC5-4E93-9C18-3866322C6AFE
    8E92F7C0-0428-4AB8-8B58-E830974838C3
    He has the Stefi G manifolds….same guy that made the cast OT pulley on my engine.  Check out his other ads…..he makes some killer (and expensive) stuff.
    https://www.thesamba.com/vw/classifieds/detail.php?id=957633
    Erik_T
    Looks great installed! Do you think the zeniths are smoother running carbs? More power? Where did you get the manifolds? I’ve only messed with WW solex copies once, they didn’t seem all that impressive.
    Thanks Franz!  The Zenith NDIX’s are for sure an improvement over the WW “Solex” carbs.  I’m really happy with them.  Idle & power delivery is consistent & smooth.  The Solex worked ok, but they weeped fuel from various locations.  No fuel weeping from the Zenith, dry.  I would say top end acceleration has improved.  Linkage is working well too, accurate tuning.  Engine also appears to be running cooler with new aluminum 356 oil cooler.  We will see for sure as summer temps increase.
    Fuel consumption has increased, because they just sound better 😀 .
    Pete is right, manifolds are from Stefi G on The Samba.  Trustworthy seller, who I’ve bought a few things from.
    1958 Outlaw Beetle
    Looks like a three man band again….😁😁😁
    Weston still there?  Or already caught up and down the road? Hopefully busy on parkway stuff..  another person helping keep the Volkswagens alive in junction!   Better make him post up his own work !!!😀
