Home Forums KCW Current Projects Parkway projects
Viewing 15 posts - 886 through 900 (of 2635 total)
  • Pat K
    Couple pics for Saturday’s paint session.DF0BBE4E-C9FD-46C4-9DFC-CCC3A1412048DEEDA505-076B-4E17-AC5D-6F40E0EA4626
    Also undercoating backsides of fenders, brush guards and batt. tray mounts. 9CA6BDCC-9C0F-4091-AA05-17CB64614DD6
    Mounted up rear tail section yesterday.  Dropped it in the process, ahhhhhh!!!  Will get that fixed up and repainted when I paint the mirror mounts. 4E8B2DE5-E97B-4B33-8D34-380ED48ECC42
    Stabbed in shift rod, hooked up drop shift coupler, and shifter. 5BB3A3AD-ABEA-46F9-815F-1F1E8E391A713C55A898-6F20-4311-B8A3-AB688D9B8DDA2016F983-CEC7-4753-8B4A-4FF93ADFCB01
    Battery mount all bolted down. Nose and doors going on today.55E261FC-045E-400F-AA34-A2F77F42E486
    BAJAMIKE
    Well the Sun Roof is in after the umpteenth time of taking it out and putting it back in final adjustments today and It is done
    So nice to see Baja Mike posting in here!!!!!!!   I really think it ads to the build and the excitement all around when the customer is apart of their thread!!!
    Pat has been dialing in paint stuff today… I am hoping it looks like a car by the end of the week!!!!! 😎
    Finished fixing my mistakes yesterday. Back to assy today.
    Tail lights and rear section installed. Doors hung. FDE601C5-412E-4559-9535-C2F493D1366340AD2360-A7C1-409F-AA7D-96349C89BE2F
    Franz has been on wiring today. 6EE4CADC-ECB7-46B6-87E2-EC779BA48739DBC5F0F9-9605-4FFA-AB30-7C4127A9FF92
    Vent wings rebuilt. Started door ACD44D52-1080-4F00-9131-D00711EC7E438520E62F-6F85-4844-9BEC-EBFC58869DD9D27C372D-4B1D-44A3-BAE8-9AF45EF5D309
    Damn! That’s a really clean baja! I like the tool tray.
    Outer trim/scrapers and vent wings in and done this morning. 2CBB1FE2-68A9-4F51-8F31-AE1B0512FDFB9E041BB1-6AA3-4DB9-87E8-88A6B7FC906A3D09DA3F-0877-4702-9972-2A671E30B61B
    Working on Mike’s baja wiring. Pat found this cool marine radio that mounts like a gauge in a 3” hole. 40 watt preout.
    3BADA776-DF15-40F8-B7CD-42A2F3F66EE0
    Finished and ready to run.
    67 ash tray
    68 fuse block with conversion clip.
    Keyed battery kill switch on the dash
    oddessey pc925 battery
    27A8E130-F527-4245-9A07-1CA68B3B8983B185C086-58B1-4FFB-B39D-F39CB218DD36
    Whipped up some speaker mounts this evening.
    11EF9647-614C-4509-8311-227DCD3D7285
    Mikes Baja is looking awesome…. Can’t wait to see the smile on his face when he first drives it!!!!!!!!!!! 😎
    This project has gone better and turned out better than I ever imagined… 😎
    BAJAMIKE
    I enjoy that fact that I have been part of the build, learning lots of things about the Baja Bug,. A Special, THANKS to Franz, Pat, and to John for allowing me to be part of the build team
    sidehill
    Pat asked me to post my work requests in Parkway-Projects.
    My Class 11 look-alike looked like this after the original builder was finished.
    surfs build from side
    The next owner started to convert it into a true Class 11 racer, so it was lowered and other mods were made to make it qualify as Class 11, and it ended up looking like this.  In this iteration the notched spring plates were removed and stock spring plates installed which rested on the stops.  So it had no up travel and was harsh and breakable IMO.
    Bug when Alan owned it-rear
    I bought the car recently and plan to use it to run in the desert and on easy mountain jeep roads.  I have lifted it back up to how it was with aftermarket spring-plates and front lift-spindles.  It now looks like this.  I still have the roof rack.
    Bug after Chad lifted it
    Pat is working on it, and the priority is to check that the valves are adjusted properly.  I believe the push rods are aluminum but I’m not sure so that needs to be checked.  If so I think the clearance should be 0.006, not loose-zero as for steel push rods.  Secondly there is some electrical work needed; tail lights.  Next it’ll need some CV work, but I’ll need to do some research on that first.  When I bought it I thought it had 944 CV’s (aka Type 4) which are good up to a 22 degree axle angle.  Pat says it now has Type 2 (bus) CV’s, only good to 17 degrees.  Apparently the fellow who wanted it to be a legal Class 11 pulled the 944 CV’s and replace them with Bus CV’s because the 944’s are Porsche and only VW parts are Class 11 legal.
    So Pat, since I need to do more research, please hold off on the CV’s and just adjust the valves properly, and fix the tail lights.  We’ll also need to talk about installing turning brakes.  I want these for traction, not for turning.  I’ll also need advice on skid plates and might have you guys build or install them.  Thanks for your help.  I’ll pick it up after the valve and electrical work and have you do the CV’s later.  Let me know when it’s ready. Thanks.
    sidehill
    Pat
    I had time to do a little research this evening and see what you mean about the clearanced Type 2 for increased axle angle.  And I see what you mean about not finding any Porsche 944 CVs advertised.   I guess they are old-school and pretty rare now.  I think the clearanced type 2 would work OK. Although the serial numbers on the CVs show it to be Type 2, I’d still like you to measure the width of the CV to be 100% sure that they’re Type 2 and not 944 (type 4).  The Blindchickenracing CV101 page shows 944s to be 34.02mm wide and the Type 2 to be 32mm.  While you have it off the flange can you also check the droop, and see if it’s properly clocked?
    I still don’t understand why neither CV clicked until the other shop greased the CVs and replaced the boots.
    I’m out of town until this weekend but will do some more research online and let you know how I want to proceed on the CVs.
    Thanks
    Sidehill
    ^^ Thanks for posting up Steve. I’ll let you know what I find.
    Fenders, bead, front turn signals, hood, and side bars all installed. D182E41F-2B26-44D5-B503-8A24DA1E964F33CB6953-FA0E-42FE-BD72-7A01F63E0F56DD73EE6E-636C-42A8-AE62-8E5CFAABC1AA
    Paint and undercoat session on a few little bits yesterday after modifying hood latches so the won’t bend. F1B2B9D4-C318-4E31-A6A9-3223E6065BA47AB62CC9-468A-4D2C-8A50-92A1C803F7B9
    Last of the parts should be arriving today/tomorrow, fuel sender and window mechs. Few little bits to put on this morning, then it’s going on the lift to bleed/adj brakes.
