Home Forums KCW Current Projects Parkway projects
Viewing 20 posts - 41 through 60 (of 1471 total)
  • Rustabus
    Damn! Love the KCW Spa treatment!!!!!!!!!!
    Jdawg
    right??? I guess I’m moving to Grand Junction so I can be closer.  😎
    Red
    I did my normal rounds on the engine, then went over and tidy’d up a few things.
    • nut-zert on the coil
    • re-routed a few wires and took off any plastic collars on connections
    • swapped faulty electronic ignition for points
    • increased idle jet to 55
    • measure/marked true TDC
    • adjusted advance base line and limit to 11-29 degrees
    • hooked-up and adjusted choke
    • removed the pre-heat flap from the air cleaner
    <iframe id=”player_1″ src=”https://www.youtube.com/embed/qu3351-j0oc?feature=oembed&enablejsapi=1&wmode=opaque&#8221; name=”fitvid0″ width=”300″ height=”150″ frameborder=”0″ allowfullscreen=”allowfullscreen” data-mce-fragment=”1″></iframe>
    Welded the spring brace back to the skin and touched up with some anthracite paint.
    Wow this thing has never run this clean, Justin is so stoked! Maybe now I can get a ride.
    Jdawg
    Wow this thing has never run this clean, Justin is so stoked! Now I need my own VW.
    fixed it for you. 😆
    Jdawg
    I’ve watched the video Franz posted about 8,432 times! Fuckin puuuuuuumped!
    Red
    Amen to that! One project at a time though….. 😐
    Red
    Guess we’ll  watch it a few more times tomorrow at work!Lol :mrgreen:
    Oldmann is sitting solidly on the ground… Franz did TONS of little things to your car..   I’ll let him fill ya in though…
    Jdawg
    bitchin! cant wait!
    Yeah man, all over it. I did some shimming on the link pins, installed a couple grease zerks, cut the shock dust covers, flipped the shocks, changed fuel hoses. Removed the hard start relay,  then fixed the root of the problem.  Corroded ignition switch contacts, battery cable, and starter.
    The glass fuel filter and this location was no bueno. Surely cause some vapor lock issues. I put a plastic filter in the engine bay after the fuel pump.
    The rear suspension had bump stops. I took them off and noticed that I could get the spring plate to bottom out on some rough stuff. I’m going to notch the plates today.
    After that I think I’ll have it pretty much dialed mechanically. I’m going to come in way under budget, and still have tomorrow to do stuff. Anything else you can think of? Paint/detail the wheels? I could pull the fender guards like we talked about. But not sure I’ll have enough time before the weekend to do correct paint repairs. You’re still coming this weekend?
    • This reply was modified 2 years ago by Franz.
    Jdawg
    dang man you’re killing it!…what is the hard start relay? yeah that fule filter was my dumb mistake…the vapor lock thing totally makes since now.
    Jdawg
    actually, I’m coming next weekend…sorry if I made it sound like it was this weekend, I meant the first full weekend of October.
    as far as other stuff goes…how about rear shocks? did you figure out what was puking fluid on the tranny? i replaced one of the boots but the other one was old…maybe replace those? the horn has never worked that would be cool to have working. are the brakes good to go? I redid them but wanted you to make sure they were adjusted and stuff. the gravel guards being gone would really cool…if you can make em go away without it being too obvious they were there go for it. i think the speedo could use some love, the odo doesn’t work and one of the idiot lights doesn’t idiot lol.
    if you have the time to keep dialing and we still have budget…dial away.
    Jdawg
    you know…………I’ve always wanted some Porsche alloys….is there a way to re-drill drums and have both bolt patterns? JJ mentioned that he had some OG bumpers…what about something like that?
    I’ve seen you guys do some bitchin headlights…the ones on there are kinda cheesy repops….
    all just thoughts…what do you think?
    Yeah I adjusted the brakes and pedal stops. I noticed that the brake fluid was dark. I replaced with new, and bleed out.
    Cool. We have time to do some stuff. I got you.
    OG exhaust clamp are a better fit.
    Jdawg
    bad ass man!!! again THANK YOU for what you’re doing! I cant explain how excited and happy I am.
    Looks like some chrome fender guards came off last night..  😉  😉   I bet Justin is all dialed in today!!!!!!   Hey….. Next weekend when you come get it… we gotta get that “Roosters” picture…. 😉  😉  😉   Remember.. You guys can stay at the compound…. 😉   No hotels..  Pat and Franz might be racing BMX next weekend.. it’s the Stat Champs…. 😉
    I’d like to be in the “Thursday Club” someday. Kinda’ out of my reach financially, so “Parkway Project” would be more like it. 😆
    Jdawg
    Hell yeah! Fuck them gravel guards…Them things suck! Where are they racing? grand junction? That would be kinda cool to see. I haven’t raced a bicycle since I was like 8 but the wife and I have some Big Rippers that we cruise around at the beach.
    • This reply was modified 2 years ago by Jdawg.
