Home Forums KCW Current Projects Parkway projects
Viewing 15 posts - 31 through 45 (of 1718 total)
  • Franz
    Drive-ability today. I was looking at the spring plates. We talked about notching them. I can’t see any marks from them bottoming out on the stops. It seemed to ride decent when I drove it. I’m going hold-off on the notches until I drive it again.
    Jdawg
    holeeeeeeeeeeeeyyyyyyy shit!!! sounds friggin awesome man!!!!! so awesome! cant believe how smooth it sounds. THANK YOU! THANK YOU! THANK YOU!
    Jdawg
    πŸ™‚ πŸ™‚Β  πŸ™‚Β  πŸ™‚Β  πŸ™‚Β  πŸ™‚Β  πŸ™‚Β  πŸ˜›Β  πŸ˜›Β  πŸ˜›Β  😎  😎  πŸ˜€Β  πŸ˜€Β  πŸ˜€
    Jdawg
    I was kind of thinking I’d like it a little lower in the back…is that possible? I love the way your red car sits…You’re probably going to say thats too low? lol
    Yeah, that is too low for a good driver. My red car drives like garbage…and wearing itself out with every mile.
    We’ll take about it more later.
    Jdawg
    ok enough said!  😎
    Jdawg
    man I’m so happy you got the motor running sweet. what a great sound after so long of hearing it struggle.
    Dario
    Jdawg
    Oh shit front end time 😎 Even Dario is hooking me up with pics! Thanks dude!
    Damn! Love the KCW Spa treatment!!!!!!!!!!
    Jdawg
    right??? I guess I’m moving to Grand Junction so I can be closer.Β  😎
    Red
    I did my normal rounds on the engine, then went over and tidy’d up a few things.
    • nut-zert on the coil
    • re-routed a few wires and took off any plastic collars on connections
    • swapped faulty electronic ignition for points
    • increased idle jet to 55
    • measure/marked true TDC
    • adjusted advance base line and limit to 11-29 degrees
    • hooked-up and adjusted choke
    • removed the pre-heat flap from the air cleaner
    <iframe id=”player_1″ src=”https://www.youtube.com/embed/qu3351-j0oc?feature=oembed&enablejsapi=1&wmode=opaque&#8221; name=”fitvid0″ width=”300″ height=”150″ frameborder=”0″ allowfullscreen=”allowfullscreen” data-mce-fragment=”1″></iframe>
    Welded the spring brace back to the skin and touched up with some anthracite paint.
    Wow this thing has never run this clean, Justin is so stoked! Maybe now I can get a ride.
    Jdawg
    Wow this thing has never run this clean, Justin is so stoked! Now I need my own VW.
    fixed it for you. πŸ˜†
    Jdawg
    I’ve watched the video Franz posted about 8,432 times! Fuckin puuuuuuumped!
