Wheels turned out great!
Tires should be here later today. Going to look awesome!
Got the wheels and tires on!! Β Found the brake line leak.. there was a zip tie in place of a hose clamp.. and it just wasnβt tight enough to do the job.. Β replaced.. Β I think we win!!
Luck is when preparation and opportunity meet.π
This will be the last βparkwayβ projectβ¦
Needs a fuel pump I heard. Β Itβs here, Β Iβll install it, then NO MORE super beetles everππ»ππ»ππ»ππ»ππ»ππ»ππ»ππ»ππππππππππππ
Noooooooooo!!! Well, yeah, ditch the Supersβ¦.BUUUT, You said you are gonna support old customers!!!! Past KCW builds get in!!!!! Thatβs gonna keep you Over Busy Forever!!!ππππ plain old upkeep Β and maintenance on the Early Shit You Already Built!!!ππππππππππππππππππππππ
What a great idea those wheels were, makes it look soooooo much better. Pat you have done a fantastic job. I can’t say enough about how well you made this old 65 look. Your time, talent and perseverance certainly show here. I can’t wait to get it……and the bill. NO complaints worth every penny. Thanks
Pat has really killed it on your ride!!Β I’m glad it’s done..!
I fixed the brake fluid leak, got the wheels on..Β Come get it!!!!!Β πΒ She’s done.
Got the wheels and tires on!! Found the brake line leak.. there was a zip tie in place of a hose clamp.. and it just wasnβt tight enough to do the job.. replaced.. I think we win!!
Gonna put the gas tank back in and wipe her down!! come get it at your earliest convenience! π
GREAT see ya Wednesday!
ππ»ππ»ππ»ππ»
This will be the last βparkwayβ projectβ¦ Needs a fuel pump I heard. Itβs here, Iβll install it, then NO MORE super beetles ever
I changed the fuel pump and filter, Β no buenoβ¦. Fuel injected.. Β I bet itβs some dumb wire or fuseββββ. Β I hate to send it home broke..
We finished this one a few weeks ago.. Β I almost said no.. Iβm closed βββ. Β But I couldnβt and this lady is sooooo nice!!!
Rinas car fired right up no problem..
CND
βcan not duplicateβ πππππ
Eric come back and see me if you see this if not, no worries
I changed the fuel pump and filter, no buenoβ¦. Fuel injected.. I bet itβs some dumb wire or fuse. I hate to send it home broke..
humm..Β has a flat too….Β Gonna toy around with it this morning..Β if it does not cooperate.. I will push it outside..
Pushed that non starting fuel injected super right across 8th street to the guys!
no more parkway work.. Β closed ββββ
