Home Forums KCW Current Projects Brown Cloud KCW baja team
Viewing 15 posts - 16 through 30 (of 803 total)
  • ColeB
    I’ll have to wait a bit to buy one… but I’ll look around. If you see anything let me know!
    $450 Baja project on Craigslist in Bloomfield NM 😉  😉  😉  😀  😀  😀
    Zack’s 69 herbie bug is out back. It has title issues…and gave its engine to the 66 project. I think it would make a good class 11 car to build.
    All it needs is a bunch of parts taken off, 7.00 x 15 tires, and a 1600cc to be class 11
    How much to turn it into this?
    How much to turn it into this?   $40,000 to $60,000 more or less ?
    Probably more like $200k
    Anyone know the modification rules for a class 11?
    Here are some rules…
    Vehicle description
    Vehicles must be a stock Volkswagen Type 1 sedan.
    Class requirements
    Safety
    A full roll cage must be installed following SCORE International safety requirements by weight of vehicle.
    Any manufacturer of seats may be used. 5 point seat belts must be used. Original gas tank may be used, but only in original mounting position. Race fuel cells may also be used in any location. Battery must be relocated. Windshield and other windows are optional. Window nets must be installed in passenger and driver windows. two headlights, two tail/brake lights, reverse light, amber light and blue light must be installed.
    Brakes
    Stock brake drums must be used, no disk brakes. Stock master cylinder must be used.
    Engine
    Engine must utilize VW series Type 1, 1600cc, U.S. model sedan and components and dimensions. Maximum 1600cc as delivered from the factory. Additional modification limitations exist. Pistons, stock 3 ring. Heads must be stock single or dual port heads 40mm. Unlimited compression, race gas OK. Stock carburetor 30 PICT 1,2 or 3.
    Class 11 vehicles typically have 60-80 horsepower. Single Carburated, dual or single port. Electronic ignitions are allowed. No dry sumps. Larger oil pumps may be installed, and external coolers as well.
    Suspension
    Suspension is stock with minor allowances to increase ground clearance and strength. Front torsion housing may be cut and rotated, torsion bars are open and may be of any origin. Front Shocks must be 2″ of less in stock location. One shock per wheel. Rear shocks must be 18″ eye to eye, and may be relocated, but must bolt directly to rear trailing arm or swing axle. Bypass shocks are not allowed. No hydraulic bump stops. External reservoirs are allowed. Rear torsion adjuster may be installed, and any torsion bar may be used.
    Body
    Body must maintain the original shape, size, configuration, and appearance. Type 1 bodies only allowed. Additional stock limitations exist for this class. No super beetles.
    Transmission
    Type 1 four-speed transaxle only. Must use stock gears, differential is open, must run a 4.12 ring and pinion.
    can’t get all james bond on that shit and use some ink removing eraser to “clear” it up…  😉  😉   some secret potion of crl and bleach…with three drops witches blood… 😉  😉
    Your serious about this huh?? 😉   this is no joke… 😀   There was a guy that used to post that had a cool red class eleven looking car…. memberdat?
    humm 🙂  😎  😎  😎
    Your serious about this huh?? ? this is no joke… ? There was a guy that used to post that had a cool red class eleven looking car…. memberdat? humm ? ? ? ?
    6footdan, if I remember right. Is a cool car. I like the ones here in this picture. Must have Subi’s in them with those skid plates. 😎
    <iframe id=”player_1″ src=”https://www.youtube.com/embed/ZTWYdVXu_WI?feature=oembed&enablejsapi=1&wmode=opaque” name=”fitvid0″ width=”300″ height=”150″ frameborder=”0″ allowfullscreen=”allowfullscreen” data-mce-fragment=”1″></iframe>
    Especially when you factor in all the charges/fines for jumping it in residential areas…
    I like this Class 11 idea Cole ? I’ll help!
    Glennmoss
    I’m so keen on this! I’d love to see KCW race! Might be able to get some sponsors to supply parts for it too.
    YEAAAAHHHHH!
    Looks like the first race in 2018 is on April 4th – San Felipe 250. Easy enough to have a car ready by then.
    http://score-international.com/raceinfo/2018-racing-schedule/
