Home Forums KCW Current Projects Juan’s 59 Lowlight
Viewing 20 posts - 781 through 800 (of 840 total)
  • Willy
    Alright! Let’s finish this. 860F2825-058A-4424-8F4C-30990FEAAE56
    Oozing class and sophistication
    Juan 59 DDWT
    Good News Franz,.. rememeber, youll receive the driver dooor glass soon, Ill let you know,….about the inside Door handle chromes, I have a guy with a original set, but he`s confirming it, I hope to receive that confirmation this week. 👍
    Perfect.
    I started yesterday with changing the ignition switch. Then put a few decals on, battery cover and strap installed, painted hinge covers,  windlace holders, and vent knobs.
    49B56E1F-2F4A-45C0-B33F-4890ADA3FC23EDDCC5C8-19BD-4DB6-856F-92DE909140CD4432FB0E-9FC1-4273-B929-9585E6D3F68C98926568-4850-4A67-85D4-EB785FBEE7BD
    Is the regulator decal correct? Where should these go?
    FBA77545-A776-4919-9BDD-0D79F495C10E
    Juan 59 DDWT
    Decal 1DecalDecal 2Decal 3
    Franz, here you see the place for regulator decal and about the year decal you can stick it right side of the windshield or the left quarter window,.. 👍👍
    The horn ring hardware and difference in 58 and 59 parts threw me for a loop…but I got it figured out.A0C4149A-DE25-4F88-9E07-57641F154DA2
    BFF9FF79-FFDB-4A39-8068-017E8CCB9CDAEB6F5483-14B8-45CE-9233-B81366A1FF29
    The new divider trim looks great!
    Dario
    So many details 🥳🤩🥰 looks fantastic!!!
    Juan, I want to order this new parcel shelf trim. Its not very expensive. Maybe it will look nicer than the scratched originals we have.
    The originals are scratched. It’s anodized surface..so not as simple as polishing out.
    5C24776B-442B-403D-A101-8B4E25035429
    Juan 59 DDWT
    No problem Franz, Please do it. 👍
    Got a bunch of little things done today…. On to installing the lowlightwerks mats! They look excellent.
    Luis says to look at his samba thread for instructions….but there are like 50 pages of the same thing.
    I just wanted to know if the tar insulation should be glued…or heated and stuck like original? Pete what did you do?
    also. I see some screw holes where the firewall mat may have been attached that way. Thinking I will avoid putting holes in it unless the purist say it’s absolutely correct.
    1EDC677A-4343-4FC9-863E-F8717E708C52D9EAFB02-4BDF-4F6C-805C-72FEA107AC67D768863D-EDD9-43F5-A8E7-9BB2BB703F990EA5E500-0679-4C70-ACB0-64C1E1D97436
    Sorry, just seeing this; my mother passed away on Friday and funeral yesterday.  Shitty week all around.
    I have not installed my set yet; I’ve had the mats forever but only recently got the sound absorber mats from Luis.  Here’s the process I plan to use.  For the mats, see post from Braukuche on this page:
    https://www.thesamba.com/vw/forum/viewtopic.php?t=155849&postdays=0&postorder=asc&highlight=sound&start=800
    For installation of the mats themselves, see rtroy’s post on this page:
    https://www.thesamba.com/vw/forum/viewtopic.php?p=8953342&highlight=installation#8953342
    I can’t wait to get mine in.  I ordered a second set of floor mats to keep mint so I could put my feet all over the other set with no worries.
    Glad this is finally coming together just like Juan wanted it to..  Franz is the ultimate finisher!
    Thanks Pete. That’s what I thought. I was worried about the glue sticking to tar.
    Sorry to heat about your Mom. My condolences.
    Thanks JJ.
    Installed the 3D printed vent knobs (thanks again Visser Precision), hinge covers with the tiny original screws. Windlace and Mat edging too.
    Notice the screw hole in the defrost heat tube? I assume that is to hold the mat up?
    2C3A93C3-25BF-4EBD-A7D5-899ED3CD72D0
    A6085257-0E27-42F9-A02F-F66F08D40235DD33195C-59CA-4440-95E2-F7CA35B9B6D3
    Thanks Franz.  It sucks.
    I think you’re correct on the screw holes. See post at top of this page:
    https://www.thesamba.com/vw/forum/viewtopic.php?t=155849&postdays=0&postorder=asc&highlight=sound&start=760
    On the bulkhead mat several folks commented that the backside needs to be cleaned of the production mold’s release agent before attempting to use a sealant to get it in place.  I think wiping it down with acetone was the agreed upon method.  Also the typical upholstery spray adhesives would not hold it.  You’ll need something like the black 3M weatherstrip adhesive.
    Juan 59 DDWT
    Thank you very much for your help Pete,.. 👍👍
    Many Good details Franz, realy Good Job,.. 👍👍
    Insulation glued in. Upon closer inspection the thick side side is rubber and sticks very nicely with contact cement.9272F4E1-A763-4109-AB03-2E122970F021CE232713-0794-40DF-8E00-F5B5560DEB821C4BB5D5-F441-4398-BA9B-1AF2E7FD699A
    After Pete mentioned people having problems with the mats sticking I decided to run 36 grit sand paper over it. 👍
    DC406111-887F-4FF7-A107-29D8FDF43850
    it fits nicely. I’ll glue tomorrow.
    75543759-168E-43FE-9282-FF6590D578E6
    Wow nice products!!
    Juan 59 DDWT
    Wow, it’s going to look really nice,🤞… Perfect Job Franz 👍😎
    Looking good, Franz.  Those floor mats have been unobtanium.  The guy making them has indicated that once he runs out of materials he’s likely done attempting to produce them.  Unless something changes Juan’s car will be one of only a hundred (if that many; likely less) that’ll have this correct detail in a restoration.
    unk
    This car is so beautiful…..its awesome.  I have never driven in a ghia……maybe some day.
