Get Brian to build you some heads๐ you wonโt be sorry
.035โ deck in the higrade kombi๐๐
And good luck on that monster surgery buddy๐ค We all be rootin for ya bro
how can you get a low enough compression to run pump gas???? ย I just donโt think itโs possible ย I wanna see the math.๐๐๐
yeah… ย I am sure my shit is worn out…. ย itโs still running.. ย sounds like itโs missing on one๐๐๐๐๐. ย I dunno.. ย I think I wanna tear it apart and go back through it allโน๏ธโน๏ธโน๏ธโน๏ธโน๏ธโน๏ธโน๏ธโน๏ธโน๏ธ ย But that does Not mean… I want a subi motor!!!!!!!!!๐๐๐๐. ย Ben told me I should keep Audreys old Vanagon and road trip it, I almost fell out of the chair he suggested it….. ย I must have been high or something๐๐๐๐๐๐ ย If I agree to road trip it, will Andy be my mechanic no matter where I break…๐๐๐๐๐
Been a wild ride, but it got me here ๐
Iโm at 9:1 it runs ย on 89 octane ๐ I think my heads are 65cc? Could get more Iโm sure if you HAD to run like 8:1
well, now that I have road tripped my motor a few times…. I can tell you, by the seat of my pants and the temp of my heat!, that lowering compression down even to 6.9 did not seem to have any positive effects and possibly negative๐๐๐๐๐๐๐๐๐๐. I know my Kombi is like 9 to 1 and it runs cool๐๐๐๐๐๐๐. Iโm going back to a normality compression next time๐๐๐๐
well I am in official quarantine now… countdown to surgery next Monday morning…6:30 am check in! ย Canโt wait to get this in process!!!!! ย They gave me the Covid test today… ย Deep penetrating q tip inserted till the bottom side of your brain is getting tickled๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค๐ค
Hope the surgery is a success….good luck!
Good luck with the surgery and recovery
Good luck with the surgery JJ…sent you an email a while back but it bounced back. Hopefully youโll be more mobile in no time ๐๐ผ๐ค๐ผ
Trust all goes well with your op JJ and youโll be springing around like your old self soon
KIM
Test Pilot @ Submarine AirwaysA few more days…. ย ๐๐๐๐๐
decided I had to get out of the house today.. ย messed with Pamper. ย Found a tight exhaust valve on number 1 and a fouled plug to go along with it. ย Points were super tight, anyway blasted the plug put it in, purr.ed๐๐๐๐๐๐๐. It also doesnโt seem to leak unless I get it super fing hot… opppps. ย I probably should get a new main seal for good measure… ๐๐๐๐๐๐๐. And of course the oil and filter… ย but otherwise… ย Iโd trust it for another trip. ย Iโd like to do a lighter weight trip on the bus to see if my heat goes down…. ย maybe a quick trip to telluride๐๐๐๐
John,
Did I hear you say something about ditching the 6.0 compression? ๐ณ๐
Pull it apart and get some decent heads on it!! ย Josh’s heads have 65cc chambers. I can also dish pistons to gain another 5cc. ย You can do the math.
Good quality new casting heads, 8.5, .040 deck and leave your w110 cam if you must. ย It will be a night and day difference. It will run cooler and make more power.
What size header do you have?
Good luck with the surgery!!
Brian
Good luck with the procedure JJ. We be praying for ya over here.๐
Iโm gonna get the CB ย book out and do the math ๐๐๐๐๐๐๐๐๐
trying to sit around and prep for this crazy surgery I have in two days. ย Rest, hydrate real good probably try not to walk out of the house Happy back easier surgery? ย ย ย I must admit.. Iโm a little nervous ๐ I mean.. shit happens…
