My old friend, Rob Cress had a functional solution for temporary driving through exceptionally hot climates. He’d drive his splits to California from Colorado pretty regularly, sometimes during the dead of Summer.
He bought one of those pressurized, aluminum can water mister systems and used one emitter that was aimed into his cooling fan. If it was really hot, he’d turn on the system and he told me it dropped his engine temperatures significantly. I’m more inclined to build a motor with whatever compression/cooling it needs but once in a while you get a scorcher of a day. Something like this could really come in handy and be a non-permanent install and you get to have a mister system at your camp site.
I actually remember chatting about the mister system going to the fan a decade ago at some VW campouts, you and Rob (RIP) we’re probably standing right there. Was thinking about that a bunch while I was trying to cross Utah and Nevada in July a couple days ago!!! 🙂 🙂
I haven’t tried it personally, but I always thought that it was a great and simple idea. Apparently this is a somewhat common technique for keeping inter-cooler temps down: https://www.enginebasics.com/Advanced%20Engine%20Tuning/Intercooler%20Sprayers.html
I wouldn’t want to run it full time, but on those exceptionally hot days it might save your motor.
I haven’t tried it personally, but I always thought that it was a great and simple idea. Apparently this is a somewhat common technique for keeping inter-cooler temps down: https://www.enginebasics.com/Advanced%20Engine%20Tuning/Intercooler%20Sprayers.html I wouldn’t want to run it full time, but on those exceptionally hot days it might save your motor.
Look into a water/alcohol injection system. Used to run an Edelbrock system on a V-8 truck engine years ago.
I’m liking this idea!!!! So should we find a 12V mister with a single jet to run behind the shroud?? I think will work!!!!
Bus is running like a top!!!! I had to adjust some points this weekend… I think they had been tight now for a week or more… Thinking that was part of my vapor locking in SLC…
Could even rig up a temp switch to turn it on and off
How about perfect size tank to fit in the corner opposite of the battery.
Put a second mister on the oil sump too?
I wonder if a fuel pump could pump water?? and be enough? 😎
Still can’t get sand off my mind.. the Sand Scorcher II idea is moving up my list…. 😎
it’s an interesting idea for sure, next thing you’ll be making water jackets for around the heads.. 😂😂
Build a sand car JJ!! Let’s see a JJ build again!!
Hah! I live! I did try to reply to the overheating head thread a while ago but couldn’t get on for some reason (probably because I’m an aussie…. :)….).
I don’t know what the thoughts on Bob Hoover are there but he did attribute the overheating head and valve problems to oil supply (heads starve, engine gets hot and then oil gets hot sorta cycle…). Interesting he did note one side was worse than the other.
Given you’re pulling it down all the time anyway maybe consider this?
http://bobhooversblog.blogspot.com/2007/05/hvx-mods.html
That was a great read… I had to read it through a few times, and also note, click on one of the pics and you get to see many more pics and how he did all of it… I am game to try.. Makes great logic.. I worry about how much the oil pressure was affected after drilling that additonal oil galley to feed the cam..??? maybe not much.. or not enough or he would have mentioned it..
I want to print it out and see what Painters thinks about it… or maybe someone who texts or talks to them dudes could send them a link… I wonder what Ross or Eddie would say…. 😎
^ now I gotta do some reading to see what the buzz is about???
Make sense.
We usually have the big oil pumps…I would think would be good for that.
Add one one of Cole’s oil sumps for a bonus with all that oil moving around the engine.
I finally found a good home for them Phone Dials…. Really like em!!!! Real wheels… and something sorta different….. 😎
<p style=”text-align: left;”>What ever happened to that shop help that got the rabbit truck?</p>
When Chris left, he paid me for it… But I always wanted them wheels back… The very first set of Phone dials I laid my eye’s on were Jack Wink’s on a black vert at the Texas Bug inn in Ennis Texas.. around 1991 ish… or 92… Always loved em… Finally have a set… Thanks Tom… 😎
