Been working on the bus when I can. Did the axle boots on trans, installed shifter, shocks, pulled apart the front window frames (need to be painted), took a look at the Jelousie windows and am wondering if i have all the parts ? Probably not. I need one more for the cut window. Was digging around through boxes of parts and found 2 workable front door handles which I was planning on buying. Just need the springs. Need to clean out the gas tank and install today. Coming along nicely.
Progress is progress!!!!!!!!!! A little each day!!!!!!!
I bet when I was putting the 65 westy back together you gave me all the jalousie window parts you need now 🙂 🙂
hahaha
I do that! give shit away that Ill for sure need again at some point. Ahhhhh fuck it ! Hopefully it helped ya out Jeff!
You told me once that you sold all the 21 window glass you had stashed and in turn maybe you’d find another 21 because you sold the stash. I hope thats the case
ps…..letter is in the mail. thx
Been working on ten DD. Found some cargo doors with the door mechanisms all intact. Removed and installed. Rods, mechs and handles.
pulled all the windows out and started checking them over I need a few handles and frame pieces.
also looking for one complete window for the cut out.
next I’ll clean out the gas tank I have and hope it’s good!
KCW website is always motivating for me
Rock on Bubba!
Looks great Bubba!
What is the engine plan?
I have a few motors here. One is a 1776cc my buddy put together that runs well and the other one will most likely get some refurbished heads from painters and a new set of pistons. 1600cc or 1776cc ?
Franz, Im hopping you’re the one to help me get the motor all dialed !
what do you think ?
I have dual port heads and manifold
Stock carb then? Bo has a case here for you too.
