Home Forums Technical Questions Axle tubes install
Viewing 4 posts - 1 through 4 (of 4 total)
  • Shane
    I am getting ready to install a rebuilt trans in my 63 beetle, and want to know if anyone has tips for installing the axle tubes, etc. I have a new gasket kit and want to know if I should use anything in addition to the paper gaskets. Do you guys use gasket sealer, like Gasgacinch or something similar? My previous trans always leaked like a sieve, and I don’t want to have issues after I finish assembly and reinstall. Any advice will be appreciated! Thanks!
    Shane
    Oh yeah, I put silicone on every seal. I know you’re not supposed to “have to”.
    And a little grease on the side cover to axle tube on the packing flower.
    Vwfool
    I have always done it exactly like Franz does.  Can’t go wrong. Make sure your axle tube flange mating surface is flat. Some of those get over torqued and wonky.
    Shane
    D174FADE-40C6-4453-B2DF-10D52CD5F52AThanks for the input. It is on the stand and ready to go. I plan to assemble everything this weekend.
