Home Forums KCW Completed Projects 66 deluxe megahatch
Viewing 9 posts - 451 through 459 (of 459 total)
  • AvatarPete
    Great shots, great bus!
    AvatarColeB
    Moderator
    Great color for the snow!
    John JonesJohn Jones
    Moderator
    Skiing at Powderhorn this morning. It was cold, but the powder was knee deep. Soo good. C42CDBB7-8C68-42C8-A956-50B8C355F92C68325625-D596-45A7-9E11-0F432F7FE8E0
    AWESOME STUFF!!!  Glad it was fun!!!!  Bus is awesome!!!!  Maybe you can drag Pat Kendall up there wth ya sometime!!!!! 😎
    AvatarMikeK
    I really like how you transformed this Bus into a useful machine.
    I read through the thread but didn’t see what you used for rear suspension.  I know it’s IRS’d, but did you use a Beetle trans and trailing arms?  What axles and CV’s did you end up using and have you had any problems related to the lifted suspension and maxing out the CV’s?  Also curious about what tires and what size was used.
    I’m putting together the rear end for my project with modified Bay trailing arms, Beetle IRS.  I was curious if I’d have to use 930 CV’s or could get away with Bus CV’s.  My old Panel was on Beetle trailing arms and I had to lower it so the Beetle CV’s weren’t over extended.
    Thanks!
    AvatarFranz
    Moderator
    I upgraded to 930 CV joints and axles because the 100mm bus units I had were clicking. Running 24 degrees on the axle at full droop (spring plate on the torsion housing stop). That is the max.
    Its all type 1 stuff, with hacked up arms and shock mounts. Old busboys stuff I think. Def not the prettiest.
    215/75/r15 tires are the biggest you can put on a stock bus, they just barely rub the edge of the jackpoint. I usually trim the jackpoint a hair.
    AvatarMikeK
    I think my old setup was Bus Boys as well.  It had the bolt on trailing arm mounts.  The one thing I didn’t car for was how de-cambered it was.  It  think that may have been from using their bolt on mounts.
    Have you had any issues with the CV boot bellows rubbing themselves and wearing out prematurely with the 930’s?  Also, did you use a floating axle or the stock ones with stops for the CV’s?
    Thanks for the info.  It’s kind of an unconventional setup and I want to get it right on paper before diving in.
    AvatarFranz
    Moderator
    New floater stuff from EMPI. You have to buy axles. 930 has different spline than VW.
    Brian from Idaho posted up some custom type 1 arms that had modified shock mounting. Looked sweet.
    Baywindow junk that WagensWest sells looks good too…but I’m not a fan of the shock behind the axle.
    AvatarFranz
    Moderator
    Getting this rig tuned-up and ready to rally. The Ottinger tour is this weekend in Moab.
    7AD39BC5-1D10-4CB2-A26E-B33F19B4A4D8
    AvatarWAY2COOL
    such a cool bus Franz
    nailed it on this one bigtime ….enjoy in large doses this weekend
    Franz subhatch
    best pic of the year !
    KIM
    Test Pilot @ Submarine Airways
  • You must be logged in to reply to this topic.
