Home Forums KCW Completed Projects 66 deluxe mega hatch
Viewing 4 posts - 421 through 424 (of 424 total)
  • Willy
    Moderator
    Where did you find your curtain rods? I like that style.
    I think Franz made them himself from jailbar ends and stainless tubing!
    JasonS
    Franz, can you tell me more about the weld in rear sway bar. I am looking for something for my bus and assume I will have a lot of weight on top also. Was thing of rear swing out racks like the RMW on the Syncro but I think it will take away from the lines of the bus.
    How is the sway bar working so far?
    Keymaster
    Great! Its kind of small for the use. But I can definitely tell that it works. Some trophy truck sway bar with billet ends mounted above the trans would be the ultimate set-up I think…But would take some careful planning to make just right.
    I plan to install a empi front sway bar in the near future. That should make it perfect.
    JasonS
    Awesome! Do you think that setup is better than the camber compensator new or original EMPI?
You must be logged in to reply to this topic.
