Home Forums Bullshit 1955 Barndoor
Viewing 15 posts - 31 through 45 (of 67 total)
  • John Jones
    Moderator
    well… even if you only bring one bus.. You can still do some vacationing and stay at the compound.. I will loan you a bus and or go with you!!!!! 😎
    That would be awesome, I don’t get to drive fully sorted out buses very often.  My passion feels reignited lately.   Spent a fair amount of time durdling in the garage.  Cleaned a few areas, check out the OG rocker!20190619_21521620190619_21515520190619_145658
    Horn was so clean inside! Shocked me.
    I guess we’re doing this.  Stupid spacer behind bearing is always in there so good!  Any tricks??
    20190620_12044720190620_131850
    Moderator
    Apply some heat with a torch usually frees up rusty junk. If no torch start treating with penetrating oil couple times a day. Gentle taps with on or those hammers ya got may also help.
    Moderator
    I use a small sharp chisel to separate that spacer from the spindle surface.
    Thanks guys, will giver a go!
    Instructions unclear, you said HEAT right??  20190620_19415220190620_194248
    Moderator
    That works. Do you know somebody with a lathe to clean those up?
    20190620_210623No.  But I can find someone,  and someone to press them apart.  Can these be flipped easily?
    20190620_211912
    20190620_21191220190620_210623
    If only it was this easy to slam it.  I don’t know anyone with a lathe but I will look, also need to press these apart and see if I can flip them??
    20190704_12003020190704_114104
    Fixing a few little things.  CLR and boom  new..ish.
    Been traveling but found time to clean up front end stuff and bolt on bumper and wheels. 20190811_162154
    John Jones
    Moderator
    pretty cool bus.. You gotta loose them big ass front turn signals next…. 😎
    Not gonna mess with hardcore welding on this one.  Got a good rear end, should be rolling…soon!
    Goter rolling and cleaned one side.
    20190818_181930
    20190818_181647
  • You must be logged in to reply to this topic.
