Lucy 64 beetle
Re: Lucy 64 beetle
Postby andym » Sat Apr 08, 2017 7:54 am
Back at it?
Re: Lucy 64 beetle
Postby Bret » Sat Apr 08, 2017 8:35 am
Im curious to see what Franz has in store in regards to those rims. Leave them all chromed or are you gonna do up the centers a different color similar to Kelly's barndoor? Matte centers and polished lip?
Re: Lucy 64 beetle
Postby Franz » Sat Apr 08, 2017 7:47 pm
No, I decided to wait on the beam project. I spent most of today digging ditch on the farm.
I did manage to find time to mask and paint detail the front wheels.
Tomorrow I think I'll work on the body.
Re: Lucy 64 beetle
Postby vwfool » Sat Apr 08, 2017 11:16 pm
I love those wheels when they are detailed. This will look sweet.
Re: Lucy 64 beetle
Postby Franz » Mon Apr 10, 2017 7:28 am
I looked up the numbers, it appears to be a matching August 63...the very first of 64 model year. Which also explains why it has a 63 style license plate light.
5864775 vin
6253511 transaxle
8055852 Engine
Crunched apron. I can fix.
Re: Lucy 64 beetle
Postby PeteSC » Mon Apr 10, 2017 7:34 am
Franz wrote:No, I decided to wait on the beam project. I spent most of today digging ditch on the farm.
Dig the Firestone tire...that thing looks pretty narrow yet tall. When you said nasty low I figured you were going with something low-profile.
Re: Lucy 64 beetle
Postby Pat K » Mon Apr 10, 2017 4:55 pm
Coming along nicely Franz. =D>
Those tires have been great for me on my 65.
Re: Lucy 64 beetle
Postby Franz » Tue Apr 18, 2017 10:05 am
The narrowest beam.
To mount the body and pan together for pulling and straitening of the bent clip. Its coming out nicely.
Re: Lucy 64 beetle
Postby rustabus » Sat Apr 22, 2017 6:57 am
Hey Franz, what height are those F560's??? 70,80 or 90??? I'm going to mount up that set of rims for Bankshot! Smile
Re: Lucy 64 beetle
Postby George » Sat Apr 22, 2017 7:20 am
The tire says f 560 in the pic
Re: Lucy 64 beetle
Postby Franz » Sat Apr 22, 2017 8:15 am
22 7/8" overall on the 125 firestone's...If you're buying new tires and want something local, go to walmart and get the 145/65 or 155/60 continetials.
Here they are on the walmart store They usually have them in stock.
Re: Lucy 64 beetle
Postby Franz » Sat Apr 22, 2017 8:43 am
I finished detailing the rear wheels and got some matching rear 205/70 tires mounted. Shooting to get this on the ground this weekend.
I'm going to hack this original beam up today.
Tyzel
Re: Lucy 64 beetle
Postby Tyzel » Sat Apr 22, 2017 9:27 pm
How'd the hacking go Franz?
Re: Lucy 64 beetle
Postby Franz » Sun Apr 23, 2017 8:15 am
I found out that I had a bent beam. #-o
Luckily, KCW had a core in the pile I was able to substitute.
I cut right behind the shock towers to get a 4" narrowed beam. I decided on a single adjuster (the bottom adjuster on a low car gets damaged). I pre-set the lower tube for slammed, I know from previous experience that center grub screw should be about strait.
Cutting the lower tube off made clean and prep much easier. I also flipped the lower tube so that the grease zerks would point up instead of down.
The torsion arm bushings are press-fit. I knock the inner bushing in 2" to match the beam narrowing. You can see the mark on my tool.
I cut up my bent beam to get a second set of press-fit inner phenolic bushings to use as outters. (this beam had needle bearing and a machined surface that was cut off in narrowing)
Re: Lucy 64 beetle
Postby rustabus » Sun Apr 23, 2017 9:08 am
Almost looks like you have done this before?? :-k :-k :-k Smile
Users browsing this forum: No registered users and 10 guests
