Shifters
Shifters
Postby BBWB » Wed Mar 15, 2017 7:45 pm
Looking at quick shifter options for small ball bus shift rod. Have a quick shift spacer setup in the bus now, although it's OK, it' not as smooth as I'd like. I remember Luftcraft put a shifter in John's old BDSC. Anyone remember the name? I think it was made in England and pretty pricey.
Re: Shifters
Postby Bret » Thu Mar 16, 2017 5:34 am
Bugtech.
They have like 62% reduced throw. Creig has one in his blue car also.
Re: Shifters
Postby BBWB » Thu Mar 16, 2017 6:35 am
Thanks, I'll check it out.
edit:
Soon as I typed bugtech in the search engine, a KCW link popped up. I was looking all over the site last night. ](*,)
viewtopic.php?t=5051
Re: Shifters
Postby Franz » Thu Mar 16, 2017 6:56 am
Small ball shifter suck. I have the best luck/adjustment with stock stuff.
Those bugtech shifters are fancy enough for a space shuttle. I don't like the reverse lock-out mechanism. It has a tendency to side load and bind on the studs.
Re: Shifters
Postby BBWB » Thu Mar 16, 2017 7:03 am
I do like the later stuff. My old '66 bus shifted like a dream even with the aftermarket extended piece.
Re: Shifters
Postby C.Hamburg » Thu Mar 16, 2017 12:17 pm
I don't know if Vintage Speed makes them for the early buses, but I have one of their new design shifters for my '65 and it works great.
Re: Shifters
Postby jb » Thu Mar 16, 2017 12:25 pm
Local buddy here here has a small ball berg in his 57 single...shifting sucks! Gregs 65 has a vintage tiwameeze speed big ball :-s me and Jrod had to crawl under that thing (slammed on 16's or 17's) with the 55 vert on a tow bar behind it all over Vancouver (in traffic) cause it kept popping out of the cup ](*,) half dozen times #-o
But I think he had more issues than the shifter?
What's stopping a guy from converting an early bus to a later shifter? Forward rod/bushing retainer and shifter? Seems simple in my mind?
Re: Shifters
Postby BBWB » Thu Mar 16, 2017 12:49 pm
^^^ I was thinking of trying that conversion. I have a late front shift rod piece and a gear shift lever. Just need the correct height cup and spring for the shift lever.
Edit:
Just saw this on Vintage Speed site.
http://shop.vintagespeed.com.tw/s.nl/it.A/id.382/.f
type4revolution
Re: Shifters
Postby type4revolution » Thu Mar 16, 2017 1:49 pm
Those are nice I use the ones with lockout reverse knob super smooth.
Re: Shifters
Postby Franz » Thu Mar 16, 2017 1:59 pm
I only use stock. No quick shift kit, no extention.
type4revolution
Re: Shifters
Postby type4revolution » Thu Mar 16, 2017 3:44 pm
Of course if you have not rebuilt with a quality transmission and shifter bushing forget having decent shifts .That's a battle you will never win.
Re: Shifters
Postby C.Hamburg » Thu Mar 16, 2017 5:17 pm
type4revolution wrote:Those are nice I use the ones with lockout reverse knob super smooth.
Yeah that's the one I have
Users browsing this forum: Baidu [Spider] and 1 guest
