Pats 65' daily
Re: Pats 65' daily
Postby john jones » Wed Jun 29, 2016 8:03 am
I may not drive a vw everyday anymore.. But if I am going out of town.. I would choose my VW over any of yours rusty.. :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-# :-#
Re: Pats 65' daily
Postby rustabus » Wed Jun 29, 2016 10:22 am
^^^^^Me Too!!! :-# Smile ^^^^^^^
Re: Pats 65' daily
Postby Pat K » Fri Jul 08, 2016 1:19 pm
^^^ I prefer to drive one daily.... not occasionally.. [-X [-X [-X ... :-# :-# :-#....love my 65' DAILY... Smile Smile
Re: Pats 65' daily
Postby Pat K » Mon Apr 10, 2017 4:25 pm
Finally wore the little lump out after 19 years of use :-({|=
Dropped the long block off at Painters a couple of weeks ago. Going with a fully balanced 1600 stocker with a fresh case. Should be ready this Fri. \:D/
Cyl. 4 . Its all downhill from here. :-s
Cyl. 3 Frown
Re: Pats 65' daily
Postby Pat K » Mon Apr 10, 2017 4:29 pm
Cyl. 2 Frown Frown
Cyl. 1 :-&
Re: Pats 65' daily
Postby tlambert » Mon Apr 10, 2017 5:06 pm
Wow that is low. ](*,)
Re: Pats 65' daily
Postby George » Mon Apr 10, 2017 5:19 pm
tlambert wrote:Wow that is low. ](*,)
Wow that's definitely a sign. Wink
Re: Pats 65' daily
Postby rustabus » Mon Apr 10, 2017 5:56 pm
Sheet! That motor will run another decade!!!! :-# :-# Not enough power to break anything!!!!! Smile Smile Smile Smile
Re: Pats 65' daily
Postby PeteSC » Mon Apr 10, 2017 6:56 pm
Don't go dropping coin on a new motor just yet - it probably just needs some Restore oil additive to boost those compression numbers back up. Smile Smile Smile Smile
Mr Grim
Re: Pats 65' daily
Postby Mr Grim » Mon Apr 10, 2017 10:25 pm
Dumb question, but did you check the valve adjustment? If the valves are out of adjustment it could cause the low compression. :-k
Re: Pats 65' daily
Postby andym » Mon Apr 10, 2017 10:33 pm
Subi bro!!!
Good to see you posting up, what do you do for nascar? Like what part of the car is your area?
Re: Pats 65' daily
Postby Franz » Tue Apr 11, 2017 7:27 am
Surprised you didn'nt go 1914cc
Re: Pats 65' daily
Postby Pat K » Tue Apr 11, 2017 4:10 pm
Mr Grim wrote:Dumb question, but did you check the valve adjustment? If the valves are out of adjustment it could cause the low compression. :-k
No I didn't. This may be the most expensive valve adjustment ever. Wink Wink
I knew this was coming. It's been eating oil for the last couple years. Happened about a month sooner then I was preparing for.
andym wrote:Subi bro!!!
Rear crush panels, fills the space between the chassis and the body. And impact foam, the blue stuff that comes flying out when the wreck.
quote="Franz"]Surprised you didn'nt go 1914cc[/quote]
Not for the daily. I have a bus to start working on soon that will need a big lump.
Re: Pats 65' daily
Postby john jones » Sat May 06, 2017 7:11 am
Get that new motor in? any new nascar upgrades?? Wink Wink Wink Wink Wink Wink
Re: Pats 65' daily
Postby Pat K » Fri May 26, 2017 10:58 am
^^ Yeah. Stacked and stabbed it over a weekend. Ran great all that week till Fri.
Then this happened
Broken throwout bearing clip. Had to go home on a flatbed. No damage luckily. \:D/
Fuel pump spit its pivot pin on Monday morning after I got the throw out bearing clip fixed that weekend. ](*,) ](*,)
Ran over to Painters grabbed a new one with c-clips on the pivot pin. Roadside fix, drove her home from work.
NASCAR. Beought home a souvenir the other day.
Users browsing this forum: No registered users and 6 guests
