Looky what I found, Bjarndoor!
dcguy
Re: Looky what I found, Bjarndoor!
Postby dcguy » Thu Jan 12, 2017 4:34 pm
Yep you guys are right, it's not Deluxe skylight glass, got my hopes up for no reason! #-o #-o
The bottom isn't too bad on it, 'usual' rust (whatever that means).
jp
carpe diem, one day, one life, no more.
Tyzel
Postby Tyzel » Thu Jan 12, 2017 5:37 pm
GTV wrote:
Bret wrote:
peashooter wrote:It looks more like cab divider glass.
That's what I thought when I first saw it. Cab divider or Single Cab rear glass.
Cab divider looks like a good bet. SC rear glass is the same as any other pre 64 non deluxe rear glass.
Actually, SC/DC rear glass up to 66 is the same as non-deluxe barndoor, not the same as 55-63 rear non-deluxe glass.
Looks like a damn decent barndoor JP!
Postby GTV » Thu Jan 12, 2017 7:32 pm
Really?! I did not know that... I helped a guy replace the rear glass in his SC once with a piece we bought at a swap meet, we both figured they were all the same, must have got lucky with what we found because it fit.
Tyzel
Postby Tyzel » Thu Jan 12, 2017 9:52 pm
GTV wrote:Really?! I did not know that... I helped a guy replace the rear glass in his SC once with a piece we bought at a swap meet, we both figured they were all the same, must have got lucky with what we found because it fit.
Ha, must have gotten lucky!
Barndoor of course ( how JP's is going to look soon Wink )
Later non barndoor SC same as above ( not the best angle in pic )
Early panel/standard rear hatch, small window.
Postby GTV » Thu Jan 12, 2017 11:16 pm
Yep, you're totally right. I never noticed how the BD/SC glass is tapered towards the top and the others are square. Learn something new every day. Thanks for the education!
Postby jb » Thu Jan 12, 2017 11:47 pm
A panel bulkhead divider uses the tapered rear BD/singlecab glass
campingbox
Postby campingbox » Fri Jan 13, 2017 6:25 am
jb wrote:A panel bulkhead divider uses the tapered rear BD/singlecab glass
I'm sure you know this but just to make it clear - both the barndoor back window and the barndoor cab divider glass are tapered but the cab divider glass is quite a bit smaller in size than the back window.
Postby Franz » Fri Jan 13, 2017 8:43 am
That would make the side glass pictured here, re-positioned cab divider glass?
Postby jb » Fri Jan 13, 2017 8:57 am
Nope I didn't know that :-" but thinking about it makes sense....this grasshopper still has much bus trivia to learn! Wink
dcguy
Postby dcguy » Fri Jan 13, 2017 2:30 pm
I am NOT a paint stripping expert, but the paint came off pretty easily and it has very strong OG color. But the problem of finding the logo is there is 2 very similar Dove Blue colors then a very light off white? It says something like, '......., we do it well!'
jp
dcguy
Postby dcguy » Fri Jan 13, 2017 2:32 pm
Tyzel, I doubt my BD will eveerrr look as nice as yours :) I won't be repainting this one so it's gonna look ratty.
jp
Tyzel
Postby Tyzel » Fri Jan 13, 2017 10:28 pm
JP, that's just a pic from the gallery here, not my BD but I wish. Looks like the og paint on yours is coming back pretty nice
Postby Slow Steve » Sun Jan 15, 2017 9:01 am
Congrats! That thing looks better than my 66 13 window...
dcguy
Postby dcguy » Sun Jan 15, 2017 10:12 am
Thanks! :)
I got it on it all 4's, but I have learned a few things about BD trans and later trans. You need a spacer otherwise there is too much toe in at the rear (later trans with RGB's and later spring plates). For now it's a roller but not possible to drive as is.
jp
Users browsing this forum: Franz and 7 guests
