Rear safari falling down
Postby 63single » Tue Oct 04, 2016 12:50 pm
I have the rear safari from wolfgang in my single cab and it keeps falling down. Anybody else have this problem and or a possible cure? I called wolfgang and they said that they hadn't heard of any issues like what i an having, but I wanted to see......thanks.
Re: Rear safari falling down
Postby BBWB » Tue Oct 04, 2016 1:25 pm
Probably not designed for wind buffet coming over the cab at 80MPH. Smile
Postby andym » Tue Oct 04, 2016 3:08 pm
I think 83 is his magic number.. :-" :-" :-"
Postby john jones » Tue Oct 04, 2016 4:14 pm
63single wrote:I have the rear safari from wolfgang in my single cab and it keeps falling down. Anybody else have this problem and or a possible cure? I called wolfgang and they said that they hadn't heard of any issues like what i an having, but I wanted to see......thanks.
my guess is it's the motor.. the soul within is rebelling.. :-$ :-$ :-$ :-$ :-$
Postby 63single » Tue Oct 04, 2016 4:31 pm
Lol, rebelling soul, hell we have set the soul free!
Postby George » Tue Oct 04, 2016 4:50 pm
Now thats funny =D>
LooseNuts
Postby LooseNuts » Tue Oct 11, 2016 9:32 pm
On your single cab? Or bus?
The single cab have the folding props right?
IG - @vwloosenuts
www.vwloosenuts.com
OGPaint
Postby OGPaint » Tue Oct 11, 2016 10:44 pm
Yes, single cabs have folding props on Wolfgang rears, so they don't project into the passenger area
I've had my singlecab rear safari for over 10 years..never had a falling down problem. I do like to drive with mine open only fully supported by one support, I leave the other support not fully braced in the "unlocked knee" position.. That way when I'm rolling and wanna close the window I just need to "unlock the knee" of the one with one hand quickly and the window closes. Easy Peazy.
Are your supports installed in a manner so the "knees lock" when the window is fully open....the little bars should just go a bit over center and sort of lock like your own knees do when moved backwards?
Anyways, the pivot rivet was getting loose from use at one time....so I squeezed it gently with my favorite vise grips. Worked great.
Postby 63single » Wed Oct 12, 2016 6:50 pm
Ogpaint, yeah, they seem to kind of lock, honestly the loose rivet might be the problem because it only seems to happen when I hit a bump. I will give that a try tonight and i'll let you know, thanks.
Postby andym » Wed Oct 12, 2016 11:47 pm
Get fronts safari and leave them open to blow through to keep the rear window open? Forced window opening
Postby 63single » Thu Oct 20, 2016 11:41 pm
Ok, so I tried to tighten the rivet, but it didnt work, but ya know what did?!?! I drilled a hole in that bitch and put a pin in it! PROBLEM SOLVED! Lol.
I used a spring release style with the locking detent. Looks less okie with an anodized aluminum pin. Anodized aluminum is for race cars!
Postby 63single » Fri Oct 21, 2016 1:14 pm
Bam!
Postby George » Fri Oct 21, 2016 4:15 pm
Clean fix =D>
Postby john jones » Fri Oct 21, 2016 4:54 pm
nothing can fix it.. :-# :-# :-# :-# :-#
Postby George » Fri Oct 21, 2016 5:41 pm
john jones wrote:nothing can fix it.. :-# :-# :-# :-# :-#
Lol your a funny guy JJ
Users browsing this forum: Franz and 10 guests
