New project in the werks for Big Ben
Re: New project in the werks for Big Ben
Postby BBWB » Thu Jan 07, 2016 1:33 pm
Sold the airframe. Kept the engine. Saving up for a kit to build a true ultra-light.
Could I take off on Kimball if I had one????
Uhhh, No. Smile
Postby john jones » Thu Jan 07, 2016 1:36 pm
like, not legal, or not enough room? Wink
RSP3
Postby RSP3 » Thu Jan 07, 2016 3:22 pm
Not legal unless you can do it at night and don't get caught!
67 Riviera Camper "Road Warrior" 2165cc, 70 Fargo fun buggy 1914cc
Postby K Leake » Thu Jan 07, 2016 3:30 pm
Ben ,have you looked at the legal eagle? It is a legal ultralight. It is powered by a half VW motor.
I sold my cessna 150 E , to buy my single cab.
I have been thinking about a ultralight.
Postby john jones » Thu Jan 07, 2016 4:55 pm
Damn..... you know......... :-k :-k :-k :-k :-k :-k :-k :-k :-k Gyro copters are about to take off... :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-$ :-# :-# :-# :-# :-# :-# :-# :-# :-#
Postby BBWB » Thu Jan 07, 2016 5:24 pm
This is what I'm after. Legal Eagle XL for larger pilots and still under the weight limit. I have the plans already. Going to buy a ,materials kits ASAP.
like not legal, or enough room?
Like not legal. You could get off easy enough down by the warehouse, but cops would be on you like stink on shite! Smile
Postby john jones » Thu Jan 07, 2016 5:26 pm
so your sayin.... we would have to take it out in the desert somwhere to fly? :-k :-k :-k :-k
I was hopin I could FLY out to the desert!!!! #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o #-o
Postby BBWB » Thu Jan 07, 2016 5:34 pm
Yep, totally legal except for national parks. Look up legal eagle XL on you tube. There is a guy built one, #94 I think. He has vids of flying all over monument Valley, Nevada, and some other spots.
Postby BBWB » Mon Jan 11, 2016 6:47 pm
Got everything back together. Heat works, but not very warm on my 10 mile commute to work. Maybe some 65mph on the highway will heat it up more. Frown These are after market heat boxes to. Don't think much of them.
Smells like pine needles and mouse urine to. ](*,) ](*,) ](*,) Flushed that tube with hot water and soap, drug rags through it, and drug more rags through with Clorox. Didn't do any good. ](*,) ](*,) ](*,) Picked up some Fabreze. I'll squirt that every 10 miles or so.
Should see you all Wednesday evening.
John, PM me Corporate's cell number so I can meet up when I get to Havasu.
Postby PeteSC » Tue Jan 12, 2016 7:01 am
BBWB wrote:Smells like pine needles and mouse urine to. ](*,) ](*,) ](*,) Flushed that tube with hot water and soap, drug rags through it, and drug more rags through with Clorox. Didn't do any good. ](*,) ](*,) ](*,) Picked up some Fabreze. I'll squirt that every 10 miles or so.
Just taking a stab here, but I wonder if you could rig up a longer spray hose and run some Eastwood internal frame coating through your heat pipe to seal it up and lock down whatever is left lurking in there? :-k
Postby john jones » Tue Jan 12, 2016 7:36 am
I can't be giving my hot mama's phone number out!!! [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X [-X
cya at BBB!!!!
Postby BBWB » Tue Jan 12, 2016 10:06 am
BBWB wrote:
Smells like pine needles and mouse urine to. Flushed that tube with hot water and soap, drug rags through it, and drug more rags through with Clorox. Didn't do any good. Picked up some Fabreze. I'll squirt that every 10 miles or so.
I'm going to take the front piece of heat tube off and then I can access better. going to seal it with POR-15.
Postby BBWB » Tue Jan 12, 2016 10:16 am
OK. I'll just look for another VW bus. \:D/
Postby john jones » Tue Jan 12, 2016 9:59 pm
pm sent =D>
Postby Pat K » Wed Jan 13, 2016 4:58 am
BBWB wrote:. Frown These are after market heat boxes to. Don't think much of them
The boxes suck?...og or aftermarket flex hose from the heater box to the heat tubes?
After markets, the insulation is really restrictive.
Clean shop cuts a piece of wire window screen, rolls it up and slips it into the flex. It expands back open and compress the insulation against the outside of the flex and opens up the center for a lot more flow.
Users browsing this forum: Google [Bot] and 3 guests
