Who's do'n work?
Re: Who's do'n work?
Postby JWDII » Thu Nov 03, 2016 7:20 am
It seems my guess was correct. I pulled my idle jets this past Friday night and one was completely clogged with a piece of plastic. I had to push it out with a wire gauge to get it clear. Reinstalled and pulled the header wrap sealed the slip joints with some copper permatex. I let it sit 24 hours rewrapped the header fired her up and we put about 250 miles on her Sunday. O:)
I guess this weekend after I get home from my fishing tournament I will change the gear oil since it will be near 300 miles on the new transaxle! \:D/
Postby rustabus » Thu Nov 03, 2016 7:29 am
Sweet!!! Land the big ones!!!! =D> =D> =D>
Postby alykat » Thu Nov 03, 2016 10:54 am
Bit more time on the TRI-Vator. Dug a junk swing trans out of the pile and bolted it in to check if I got everything square (and make it a full roller) so now I can test fit the fiberglass inner panels and see where my controls should go.For shure will need to re-index the torsions.
crb 003.jpg (104.45 KiB) Viewed 518 times
Postby john jones » Thu Nov 03, 2016 10:57 am
alykat wrote:Bit more time on the TRI-Vator. Dug a junk swing trans out of the pile and bolted it in to check if I got everything square (and make it a full roller) so now I can test fit the fiberglass inner panels and see where my controls should go.For shure will need to re-index the torsions.
I don't know why.. but I have some odd fascination with that rig... #-o #-o #-o #-o #-o #-o #-o #-o #-o
Postby alykat » Thu Nov 03, 2016 11:01 am
Hell John, it could be yours in a heart beat ! \:D/ They look different when finished out.
Phat Bug
Postby Phat Bug » Thu Nov 03, 2016 12:04 pm
Holy shit that thing is badass^^
Postby john jones » Thu Nov 03, 2016 12:04 pm
does it have a title?? unlikely I know... which means it would probably be a bitch to register... :-k :-k :-k
Postby alykat » Thu Nov 03, 2016 12:26 pm
Actually I do have a couple of options there. I have a titled pan section with the vin numbers but all of the tunnel is cut away from the torsion on the space frame. Need to figure out where the section could be welded to the new frame and visible for inspection and would satisfy the DMV. Another is to find a wrecked car with an engine and body tags that match the title and go with those.
Postby K Leake » Fri Nov 04, 2016 7:08 am
Been making some book shelf's for my wife, I have one put together, I need to glue up the faces of the shelf's, for the second half. Stain and finish
Postby K Leake » Fri Nov 04, 2016 11:45 am
Getting closer, waiting on the last three shelfs to dry .
Postby alykat » Fri Nov 04, 2016 11:58 am
Another step on the TRI-VATOR. Fit the fiberglass cockpit floor pan. Next is test fit pedal assembly and lay out brake lines and shifter location.
T3-11416 004.jpg (81.16 KiB) Viewed 396 times
Postby K Leake » Fri Nov 04, 2016 12:22 pm
That looks like a wild ride O:)
Postby john jones » Sat Nov 05, 2016 5:27 am
kevin you really know how to work that wood... :-# :-# :-# I bet you could build a KILLER camper interior!!!!!!!!!!!! =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
How about I internship with you for a month and you teach me :-k :-k :-k :-k :-k :-k If I can't weld it.. I can't work with it.. :-# :-# :-#
Postby K Leake » Sat Nov 05, 2016 8:46 am
john jones wrote:kevin you really know how to work that wood... :-# :-# :-# I bet you could build a KILLER camper interior!!!!!!!!!!!! =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
That would be fun. O:) the hard part of working with wood for me , is the waiting for glue to dry . Being patient. Working with metal. We fit and weld . O:) but I have never ever done body work . I was a pipe fitter, welder . O:)
Phat Bug
Postby Phat Bug » Mon Nov 07, 2016 8:35 pm
Threw the rear rims on the front of my Baja fasty and set her down, just to get a feel for it..........
The front rims have a different offset and a slightly smaller tire, but you get the idea. Pretty happy with the stance \:D/
