1959 Porsche 356A - Now Lowered!
Postby GTV » Fri Apr 27, 2012 5:30 am
OvalTeen wrote:Killing it!!!
I cant compete with this =D>
You could if you did something other than flip shit!!
dcguy
Postby dcguy » Fri Apr 27, 2012 7:10 pm
Frustrations today!! I got my VW engine running (for me that's an accomplishment!) BUT, I had starter problems. If anyone can help??
I was testing an engine (40hp w/ 6v flywheel) on the ground. The trans was a 1969 IRS. I had 2 starters (both 6V, one a VW one Porsche high torque).
- When I install them correctly both starters squeeled, ie not catching the flywheel.
- When I loosen the bolts and engage the starter at an angle, the engine started (horrible grinding noise, but it started).
What could be the problem??
More info; The Porsche high torque has a 6V pinion and it's self supporting. The VW starter, I installed the correct bushing.
Also, I installed the engine into my Porsche 356 (644 trans) and same thing! Squeels if tightened the bolts, but engine starts if I angle the starter. What gives? I tried shimming it but it didn't work
Postby C.Hamburg » Fri Apr 27, 2012 7:27 pm
Starter bushing jacked up?
dcguy
Postby dcguy » Fri Apr 27, 2012 7:46 pm
The VW starter/bushing were ok. And the Porsche starter is 'self supporting', it doesn't need a bushing (like an auto tranny starter).
But the same thing happened in the Porsche trans! Sad end to the day!
dcguy
Postby dcguy » Sat Apr 28, 2012 5:40 pm
VW engine in and running! I have the starter issue, I will contact Al Zim and see what's up. Apparently they've had issues with those starters half contacting the flywheel and they keep selling them!! [-(
How it sits after the engine weighs down the back!
Spent yesterday and today with this (mostly the starter, install remove engine two step). Oh well, I can always push start it :)
Also got alot of the electrical sorted out.
dcguy
Postby dcguy » Mon Apr 30, 2012 7:05 am
Hi guys, nothing too exciting or photographical stuff to report. The problem with living so far away from the car meccas is that parts take forever to get here, there's not much in the way of real technical help here for this old car (that I can afford anyways!).
-Brakes are bled
-Working on over the tunnel shifter as the 'monkey' motion shifter is $$$ and a little screwy
Ordered some interior bits and I'm trying to figure out the best way to do the inside.
I also want to thank KCW for having an open and free forum plus this brilliant monthly build thread idea. Ideas like this keep things fun and fresh! Never take for granted how beautiful such a simple thing can be. Just check out the snobs over on the 356 Registry, things can change VERY quickly so vigilance is required! :)
Postby Franz » Mon Apr 30, 2012 7:15 am
So it turned out to be a manufacturing error on the new starter?
dcguy
Postby dcguy » Mon Apr 30, 2012 7:52 pm
Franz wrote:So it turned out to be a manufacturing error on the new starter?
Yup! Al Zim even said the 'early' batch of starters were defective, but lucky me must've got one. It doesn't extend far enough to allow it to catch the flywheel.
Some people posted on the Registry how the starter would 'half' engage and chew up their expensive 356 flywheels. I can send it back and they 'will look at it'. Fun.
I'm going to try a 6V starter from VW and see if it fits.
Postby rustabus » Mon Apr 30, 2012 8:29 pm
Awesome progress!!!! Too bad about the starter, glad it is just a little setback Smile
dcguy
Postby dcguy » Mon Apr 30, 2012 8:32 pm
We push started it :) That's not going to go over too well with the wife. She's only 105lbs and she's just not that strong.
Oh well, nothing like pushing 1700lbs to build those muscles!!
Postby VWsArent4Hippies » Wed Jul 04, 2012 12:33 pm
When did this car end up in California? Did you even list it or was it behind the scenes?
http://www.thesamba.com/vw/classifieds/ ... id=1322035
dcguy
Postby dcguy » Wed Mar 06, 2013 5:55 pm
VWsArent4Hippies wrote:When did this car end up in California? Did you even list it or was it behind the scenes?
Um, yeah, here's the details you're looking for. First that happened, than this happened and, pay close attention to this part because it's none of your fucking business!
Ta da!! \:D/
Postby Franz » Wed Mar 06, 2013 6:13 pm
Wow dude. Not cool
smittys66dlux
Postby smittys66dlux » Wed Mar 06, 2013 6:54 pm
You waited 9 months to reply with that?? :-s [-X
It's not going to finish itself!
dcguy
Postby dcguy » Wed Mar 06, 2013 6:56 pm
He follows me around on all my posts, posts snide comments (that's being nice), and I've had enough.
I've tried to ignore some stuff, but I just read this (today) and I snapped. No apologizes, I meant what I said, it's none of his business.
