low single cab, body off
Heinz Willie
Postby Heinz Willie » Mon Apr 16, 2012 8:35 pm
Nicely done =D>
A wrench around... It's how you get your nuts off !
speedjeans
Postby speedjeans » Tue Apr 17, 2012 2:32 am
spotwelded in one side
some more welding and grinding
removable for easy access
Postby Franz » Tue Apr 17, 2012 7:49 am
You are a wizard. So, the side will be removable?
speedjeans
Postby speedjeans » Tue Apr 17, 2012 8:54 am
YES.. all panels will be removable.
main raison is the rear wheel removal.
installed the rear panel. Have made the wheelarch real low.
started with the pax side
dcguy
Postby dcguy » Tue Apr 17, 2012 2:08 pm
I love that spot welded look! Don't grind them down :)
speedjeans
Postby speedjeans » Tue Apr 17, 2012 2:39 pm
GOOD IDEA ;-)
maybe I will leave the outer ones vissible..
dcguy
Postby dcguy » Tue Apr 17, 2012 3:18 pm
Uh oh, was I being Captian Obvious there?? :)
speedjeans
Postby speedjeans » Tue Apr 17, 2012 3:23 pm
no.. is a good idea..
Cuba
Postby Cuba » Tue Apr 17, 2012 5:13 pm
This Thing is bad ass =P~
speedjeans
Postby speedjeans » Thu Apr 19, 2012 3:22 pm
thanks for the positive responses
rear corners were quite crunchy, so time for some new metal.. No, noting new, just patching..
and the pax side
grinded down the welds
tommorow the rear wheel panel..
also the sideplates for the beam are now cut..
see my facebook link:
http://www.facebook.com/photo.php?v=3759315380771&set=vb.1213126702&type=2&theater
speedjeans
airbeam
Postby speedjeans » Mon Apr 23, 2012 2:12 pm
lately not much welding, just some work on the beam..
the lower one is the airbeam..
testfitted under my flinstones panelvan for easy access.
just tacked.. still needs the steeringpin, adjuster and some small tweeking.
with the testing still cannot go low enough, so need to change the angle of the arms.
video of the beam up/down on my facebook-link:
http://www.facebook.com/video/video.php?v=3820962561912
speedjeans
Postby speedjeans » Tue Apr 24, 2012 3:17 am
Does anybody know if the front 63-70 brake cilinders/pads will fit on 55-63 backingplates/drums if I replace them as a complete set?
Postby Franz » Tue Apr 24, 2012 6:26 am
Nope, bus brakes are not interchangeable. You have to have the complete brakes to match the style spindle you have.
Postby vwfool » Tue Apr 24, 2012 9:21 am
What is the story on the gold metallic bus beam? That is out there. Don't show Kevin, he will leave Kawasaki green in the dust and do gold metallic everything. \:D/
