Geesons master cleaners 59' kombi IS FOR SALE
durfeec
Postby durfeec » Sat Jan 21, 2012 9:08 pm
how was the curve on that rocker? is that a WW or CIP rocker?
1960 Panel/Camper
Dan-o
Postby Dan-o » Sun Jan 22, 2012 9:15 am
Jobe wrote:
Franz wrote:Here the U joint I think you want. I'm getting ready to do the same thing on the 911/bay project. I have tried using socket wrench u joints in the past...they always fail. The problem is the rotational play. The u joint has to be tight or you won't be able to rotate the shift rod enough to get all of the gears.
http://secure.chassisshop.com/partlist/6082/
Thanks Franz. I'll try those.
I don't know if these would work, but I thought I would pass it along because they are pretty cheep and German. The ones Franz posted are a lot cleaner looking though.
Before you criticize someone, you should walk a mile in their shoes. That way, when you criticize them, you're a mile away and you have their shoes.
Postby Glenn A » Sun Jan 22, 2012 9:34 am
I picked up one of these for my project. The only draw back is you need to have it bored to the correct size of the trans and shiftrod.
http://www.grainger.com/Grainger/LOVEJO ... vc=IDPBBZ2
sled
Postby sled » Sun Jan 22, 2012 10:20 am
version 2.0? looking forward to it!
to each his own
Postby frvngn » Sun Jan 22, 2012 10:24 am
sled wrote:version 2.0? looking forward to it!
Nice.......don't you mean: version 2.LOW...... =D>
Postby DaKine » Sun Jan 22, 2012 10:54 am
So sick, last I heard that bus was heading to the right coast...that was a while back
Postby Pigpen » Sun Jan 22, 2012 11:10 am
That bus is bad ass...
Postby C.Hamburg » Sun Jan 22, 2012 12:38 pm
Yeah I heard it made it to Florida and guy is getting it restored.
Greasy Dave
Postby Greasy Dave » Sun Jan 22, 2012 1:12 pm
On its way to the United Kingdom now \:D/ .Check out Busjunkie.com
Postby Jobe » Mon Jan 23, 2012 9:30 pm
The hatch is pretty wasted on this so im going to clean up this 62 hatch and make it nice for the 59'
Its really straight and solid
Being a bit later it has that funky pressing in it that i have to cut out and weld up.
Postby Franz » Thu Feb 02, 2012 3:38 pm
Jobe's doubling up this month!
Postby Jobe » Thu Feb 02, 2012 7:17 pm
Franz wrote:Jobe's doubling up this month!
Yeah buddy! Ill try not to slack off too much. Hopefully this blizzard warning doesnt last and i can keep up on the progress/ make up for what i didnt get done off my january goals.
The parts to tidy up the trans and the IRS trailing arm brackets came in today. Now how the heck do i figure out the position to weld these in at for the irs conversion into a type 2?
Sled?
Postby Jobe » Fri Feb 03, 2012 11:03 pm
How well do the wolfsburgwest fat lip doglegs fit? anyone have a negative opinion of them? :-k
http://www.wolfsburgwest.com/cart/Detai ... =211809501
Postby Franz » Sat Feb 04, 2012 8:35 am
They're beautiful.
Postby VWsArent4Hippies » Sat Feb 04, 2012 8:51 am
