el Westy's motor build
splitpile
Postby splitpile » Fri Dec 09, 2011 10:49 pm
Buy a set of GOOD ported heads with matching manifolds. I use either Tims stage 1 or CB's Los Panchito's. Both great heads that work awesome good for 10 to 30 hp out of the box.
Shit load of buses and even more parts
Postby GTV » Fri Dec 09, 2011 10:58 pm
Flywheels don't help you get up hills, horsepower does. A heavy flywheel makes it easier when you drop the clutch from a dead stop, that's it.
OgCalLook
Postby OgCalLook » Sat Dec 10, 2011 11:04 am
Engle did change their cam billets, and as long as you use engle lifters, your ok.
Otherwise you need to make sure the Rockwell hardness for the Cam and the Lifters are compatible.
Tom
el arod
Postby el arod » Sat Dec 10, 2011 11:40 am
OgCalLook wrote:Engle did change their cam billets, and as long as you use engle lifters, your ok.
thanks for the update.
alex
"Trailer?" "Those are for boats!"
Postby Jobe » Sat Dec 10, 2011 12:26 pm
Thats interesting information.
I wonder why Engle switched, It seems they have a pretty consistant backround for reliability.
OgCalLook
Postby OgCalLook » Sat Dec 10, 2011 2:24 pm
Im not sure, but when SoCal Imports bought Engle a couple of years ago, they started promoting their lifters, and spring kits. They'll warrantee their cams, if you use their lifters.
With the old CWC blanks, we would run empi billet lifters with tons of spring pressure and no wear issues/no failures.
The new SC-1 blanks start to pit right away with those same lifters. I'm now running engle lifters, and Brad Penn oil (for the ZDDP)
So Something changed....
Steve Long (SLR) in Corona has a good rep for providing matching Cam & Lifter hardness.
Tom
Postby DaKine » Sun Dec 11, 2011 4:13 pm
Good luck with it Alex. An engine build is one thing I've yet to attempt...maybe your work will motivate me to give it a try... :-k
I've got a feeling January is going to fly by... \:D/
Postby john jones » Wed Jan 11, 2012 7:26 am
You'll love the new bigger motor.. 2liters in a bus are the only way to fly... especially on long road trips.. There are some big ol hills in colorado and utah..
el arod
Postby el arod » Thu Jan 12, 2012 6:14 am
john jones wrote:You'll love the new bigger motor.. 2liters in a bus are the only way to fly... especially on long road trips.. There are some big ol hills in colorado and utah..
roadtrip?--DAMN RIGHT! i am all about driving my westy!
still waiting for the check to get this project started. they told me its in the mail ](*,) they said 3-5 days; today is day 4 [-( i know i am out of contention for jan.
alex
