V8 mid engine 4wd bay
Re: V8 mid engine 4wd bay
Postby alykat » Sun Apr 30, 2017 8:24 am
Are all the mechanicals sorted now ? Ready for body mods ? \:D/
roverv8bay
Postby roverv8bay » Tue May 02, 2017 1:38 am
G'day all. Alykat the front wheel drive assembly is finally sorted now start on the rear differential tailshaft & axle shafts. I have the diff mounting sorted just have to find the final position for it so I can measure up and build the rear tailshaft. I have ordered new rear hub bearings then simple matter of bolting the rear brakes together. most of the engine ECU wiring is sorted now to fit & solder plugs to it.
Postby alykat » Tue May 02, 2017 7:08 am
Sounds like positive movement. =D>
